<<  1    2  >>
New Topic New Reply
Author: Subject: footwell access hatch complete, lots of pictures
40inches
posted on 23/9/12 at 08:41 PM Reply With Quote
Originally posted by FuryRebuild
HI 40 inches
The fury chassis is already very strong (I've had one off on the track with it), but where my feet are concerned, I wanted it in a nice, strong sealed box regardless. That's also why I've used nitrile rubber for the gasket; it's fuel proof and means I can maintain a full fluid seal to the engine bay and it'll clamp down good and tight and never rattle.
The effort in doing all the holes in cad was about 30 minutes, and it took more time to align the parts to do an interference fit check than it did to make the holes, panels, etc.
That sounds reasonable The MK footwell is a welded steel box, so I suppose a light lid is acceptable.
FuryRebuild
posted on 23/9/12 at 09:04 PM Reply With Quote
Yeah - the original fury pedal box is 1.5mm folded and stitch welded. It's not a bad affair, but isn't compatible with a good pedal-box and was designed for cable, not hydraulic clutch. Even after the pedal box, there isn't room for the duratec housing. Either way, it was coming out and the new shape was necessarily more complex to handle the bellhousing and travel for the pedals.
Here's the top down view of it all tacked in place. You can just see the throttle pedal poking through ready to get a little box made for it.
Here's the view ready for the brake cylinders to go in. I only had one bolt-hole with a missmatch, and it needed opening out by 1mm.
All that remains is to put the complex transmission tunnel panel in, but that will require taking the engine off its mounts and moving it over a little. No hassle doing this.
Once complete, the engine and box can come out so everything can be seam welded.
I deliberately made the side panel in several pieces to be welded to the cross members. The main reason for this was to be sure the sand-blaster and powder-coater could get in there and no panel remained exposed.
www.furyrebuild.co.uk
FuryRebuild
posted on 23/9/12 at 09:07 PM Reply With Quote
Roadkill
My panel is round, yours is square. I used nutserts. I think we're fine for patent battles.
40inches
posted on 23/9/12 at 09:16 PM Reply With Quote
That will look the biz when it's all powder coated. Good feeling when a plan comes together, isn't it?
loggyboy
posted on 24/9/12 at 01:25 PM Reply With Quote
Was the gasket cut out of a large sheet or a carefully placed 1inch wide roll?
Mistral Motorsport
FuryRebuild
posted on 24/9/12 at 01:30 PM Reply With Quote
Hi loggyboy
It's 3mm fuel resistant nitrile, water jet cut to my pattern. It was the most expensive part and I also bought a spare.
loggyboy
posted on 24/9/12 at 01:36 PM Reply With Quote
Thats all i need to know, i'l stick with the plan to use this for my pedal box seal! NEOPRENE RUBBER SELF ADHESIVE STRIP 25mm x 3mm X 10MTR | eBay
Mistral Motorsport
FuryRebuild
posted on 24/9/12 at 01:47 PM Reply With Quote
That's a good choice.
I wanted to be sure I was protected from the fuel, but at the same time that was the stock rubber my engineering shop carried. The gaskets were £25 each! Needless to say the costs come down considerably when ordering in bulk
posted on 25/9/12 at 06:11 PM Reply With Quote
I like the detail and execution of the design myself. I've been following your rebuild for a while and like the attention to detail you're applying. Should be a very tidy car when completed and very satisfying too.
JonT
posted on 25/9/12 at 06:28 PM Reply With Quote
Holy moly, that's a recipe for RSI
I also have just four bolts on the cover over my Striker footwell. Definitely agree it's VERY handy to have...there are just sometimes some jobs where you don't want to be hanging upside down in the footwell with your feet dangling over the rollbar...been there before!
Jon
"People were created to be loved, things were created to be used. The reason why the world is in CHAOS is because things are being loved and people are being used"
mcerd1
posted on 27/9/12 at 12:39 PM Reply With Quote
personally I think its a bit OTT but very nicely executed
but then plenty of folk on this site have gone way OTT on at least one part of there cars….
I don't even want to admit how much time, effort and cash have gone into some bits of my car - and mine doesn't even look like a car yet !
FuryRebuild
posted on 27/9/12 at 02:30 PM Reply With Quote
Hi Mcerd1
It was a pain when I originally built the car, so I wanted to do something very different.
Designing the parts for the top and hatch, gasket etc. wasn't too much effort; probably three hours all in. The footwell needed replacing anyway to accommodate the pedal box. Of the 3 hours, maybe an extra 30 minutes went into the extra design of the hatch.
It takes about 5 mins to screw all the cap-screws into place with a good electric screw driver; not a major hassle for something I never intended to be an on-again, off again part.
You're right - we all tend to obsess about some things. I wanted the pedal box to remain very strong even with a gurt hole cut in the top, rather than lose it's structural integrity.
It's taken a lot of time to seam weld it all in place (rather than stitch) but I'm nearly there now. Once it's powder coated, it'll look the muts. I remember watching an episode of top gear where St Jeremy got the bonnet up on a Alfa 3.0 156 and pointed out that the exhuast manifold pipes were chromed. Unnecessary but great. I think I've engineered my bits a bit the same, but I was working to my own spec of "lots of access, lots of strength, no rattles, reliable fluid seal in the bulkhead area".
Of all the panels I designed and had made, this is my favourite. It gives the clearance around the bellhousing at the same time as enough clearance with the clutch pedal. It was bent up from flat, and when bent properly, the slit is less than 0.5mm wide.
mcerd1
posted on 27/9/12 at 03:10 PM Reply With Quote
I feel a new thread coming on here
Originally posted by FuryRebuildI think I've engineered my bits a bit the same, but I was working to my own spec of "lots of access, lots of strength, no rattles, reliable fluid seal in the bulkhead area".
Sound like my plan for this area on my dax, although strength should be much less of an issue (the dax chassis is quite different)
I take it you had that waterjet/laser cut too ?
for the most part I'll end up just using my dads guillotine and box pan folder with some thin alloy sheet, not quite as fancy but it should make a neat enough job
FuryRebuild
posted on 27/9/12 at 03:47 PM Reply With Quote
Yes - that was laser cut and put through the robot press brake.
I think you'd get very good results that way - I happened to have good CAD software and went down that route but it did feel like evenings working on the CAD weren't getting my hands dirty but now it feels like good time invested. there were only a couple of parts that didn't fit perfectly, and a little adjustment did the job.
FuryRebuild
posted on 29/9/12 at 04:45 PM Reply With Quote
time to undo the panel using an electric screw-driver: 2:50. Not a major ball-ache.
Furyous
posted on 29/9/12 at 08:00 PM Reply With Quote
That's less time than it took me to get the 8 screws off my access panel after finding the cap heads had rounded off and none of my allen keys fit.
What about when you have the steering rack and other things in the way?
[Edited on 29/9/12 by Furyous]
DIY Si
posted on 1/10/12 at 09:01 PM Reply With Quote
More importantly, how long when the screw driver's flat, it's dark and the throttle cable's snapped?
Note, I've only ever had to do this to mine in the day light. But the MK roll bar is just the right height for my feet to rest on! Although it did give the police officer pause when they came to see what the problem was.
Sun Tzu, The Art of War
<<  1    2  >>
New Topic New Reply
