MikeFellows
| posted on 2/3/10 at 08:13 AM |
Hole in MK chassis where steering column goes through
There is a hole in the MK chassis (a big round hole) that the steering column goes through to attach to the linkage bar.
I need something to go in the hole to stop the steering column having play in it.
does that make sense?
jabbahutt
| posted on 2/3/10 at 08:21 AM |
use the original Sierra steering bush, should comprise of 3 items. A plastic cylinder with a triangular hole in it for the column, a large rubber
bush the fits around the outside of the plastic part and goes in the hole and a large metal disc with a triangular hole in it which keeps the hole
assembly together as it's a tight fit on the column.
If you haven't got it they should be available from Ford.
Nigel
[Edited on 2/3/10 by jabbahutt]
BillHoll
You need the steering column bush from a sierra. It consists of a rubber grommet and 2 plastic parts. About £4 on ebay.
MikeFellows
| posted on 2/3/10 at 08:22 AM |
thanks for that
will pop to my local motor factors this morning.
stevec
| posted on 2/3/10 at 09:03 AM |
one of these.
ashg
| posted on 2/3/10 at 11:34 AM |
they are £4 on ebay. there are loads if them. just typed sierra column bush in the search.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
| posted on 2/3/10 at 07:01 PM |
Do a search for steering column bearing , made a huge difference to my car when I fitted it instead of the standard Sierra bush . Make self centering
a lot better as it doesn't bind on the column
40inches
| posted on 3/3/10 at 03:46 PM |
Look HERE
MikeFellows
| posted on 3/3/10 at 09:52 PM |
Thanks for that, I was about to order a £4 replacement, that looks a much better solution
