<<  1    2  >>
Author: Subject: Speed sender
ChrisW
posted on 19/11/03 at 08:26 PM Reply With Quote
Speed sender
After a speed sender for my digital dash project. Are any Fords fitted with them as standard? Failing that, anyone used an after market speedo with a separate sender? I would rather avoid the whole 'magnets on the prop shaft' trick
Chris
My gaff my rules
Metal Hippy
posted on 19/11/03 at 08:29 PM Reply With Quote
Some Vauxhalls had them...
Cock off or cock on. You choose.
ChrisW
posted on 19/11/03 at 08:32 PM Reply With Quote
Fool.
Chris
My gaff my rules
Metal Hippy
posted on 19/11/03 at 08:34 PM Reply With Quote
I know you said Ford ya ginger gimp but I just mentioned it as another avenue you could look into potentially.
ChrisW
posted on 19/11/03 at 08:44 PM Reply With Quote
You can't talk about hair
Having taken the wee you may actually have a point. Anyone know how Vaux speed sensors connect to the running gear?
Chris
My gaff my rules
Metal Hippy
posted on 19/11/03 at 08:47 PM Reply With Quote
Yes I can, I'm fully able to talk about h... h... ha... ARSE.
Oh well, maybe not.
posted on 19/11/03 at 09:08 PM Reply With Quote
I think they use sellotape, or do they read a toothed trigger disk mounted on the crank. I think it's the latter.
yours, Pete.
posted on 19/11/03 at 09:23 PM Reply With Quote
Don't You Just Love It....
The friendly banter!
Oh and "Lord" - the Scampi, saw it after you posted the badger's one... badger is the best!
still prefer beaver tho'...
Metal Hippy
posted on 19/11/03 at 09:24 PM Reply With Quote
Genie Arse
Alan B
posted on 19/11/03 at 09:48 PM Reply With Quote
Pete...sensor on the crank is fine for RPM....but wasn't Chris looking for Speedo input?
Hmm...sellotape is correct.....
Mark Allanson
posted on 19/11/03 at 09:54 PM Reply With Quote
Fine if he keeps it in first gear
Alan B
posted on 19/11/03 at 10:19 PM Reply With Quote
See.....I always miss the obvious answer....
zetec
posted on 19/11/03 at 10:23 PM Reply With Quote
Ford MT75 gearbox has a speed sensor fitted, not sure if all models but anything fitted with injection or ABS is a good bet. Good output signal as well.
ChrisW
posted on 20/11/03 at 06:05 PM Reply With Quote
Been offered an MT75 one and one from a Fiesta Si. Anyone know if either of these will fit a type 9 g'box?
Chris
My gaff my rules
ChrisW
posted on 20/11/03 at 06:43 PM Reply With Quote
Cheers Syd. Ideally I'd like to have it connect straight up but I guess the cable option is there if I can't!
Chris
My gaff my rules
zetec
posted on 20/11/03 at 08:43 PM Reply With Quote
The speed sender on the MT75 is built into the gearbox casting, you would need to use the whole gearbox, same mountings as the type9 and stronger.
AvonBelgium
posted on 20/11/03 at 11:23 PM Reply With Quote
Have a look here
Nordskog
theconrodkid
posted on 21/11/03 at 12:22 AM Reply With Quote
there is an mt75 one kicking around in your barn chris,your mission is to find it
who cares who wins
pass the pork pies
Ben_Copeland
posted on 21/11/03 at 09:21 AM Reply With Quote
Runs off the gearbox.... same place as the cable drive ones
Looks like that
Transducer
Transducer
Chris
[Edited on 21/11/03 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
dblissett
posted on 21/11/03 at 08:27 PM Reply With Quote
type9
i have taken a type 9 out of a injection grandad its has no cable drive and an electronic speedo so it must have a senser in there
Metal Hippy
posted on 21/11/03 at 08:45 PM Reply With Quote
Chris has more than enough space in his Luego Syd... Talk about wide ass....
stephen_gusterson
posted on 21/11/03 at 11:30 PM Reply With Quote
I can back that up. my V6 cologne with type nine from a E granada does indeed have a speed sensor and not a cable.
atb
steve
ChrisW
posted on 22/11/03 at 12:04 PM Reply With Quote
Anyone want to part with their type 9 speed sender? Thats assuming it would fit on a 'cable' type box.
Chris
My gaff my rules
stephen_gusterson
posted on 22/11/03 at 08:47 PM Reply With Quote
your local breaker might
atb
mr obvious
ChrisW
posted on 22/11/03 at 11:36 PM Reply With Quote
Probably, but thought I'd try you lot first. Surely you're all fitting 'normal' instruments (with cables!)
Can anyone confirm if it will fit a 'cable' type 9 box?
Chris
[Edited on 22/11/03 by ChrisW]
My gaff my rules
<<  1    2  >>
