Doctor Derek Doctors
posted on 9/12/13 at 08:40 PM |
15" Image Split Rims & A048 tyres.
It's with great sadness that I'm selling these wheels as they are absolutely stunning but 13" is what I need for competition and I
can fit tyres to them myself.
Anyway, for sale a set of Image 3 piece cast split rims, style is BPS in Gun grey with polished outers. I believe they are 6" wide with a
1" wide outer rim (I will measure the offset if anyone is seriously interested).
They are ford fit 108 PCD with and ford fit centre spigot and tapered wheel nut seats (not the ford type top hat nut) all centre caps are present.
They are fitted with hardly used Yokohama A048 medium compound tyres 195/50/15 size (have done 2 dry trackdays where we were running in the car, and
one wet day where we did about 10 laps at a snails pace)
Also worth mentioning that they are fitted with BBS bolt in aluminium valves supplied for their GT racing wheels, not crappy rubber ones
They are practically unmarked (slight marks where tyres were fitted), no chips and dents.
These wheels are £250 each from image and the tyres are £150 each so £1600 a set!
I'm looking for 1/2 that so £800.
I know it's a lot but it's breaking my heart to sell them and they are truly gorgeous wheels, if you've spent time and effort to
make a nice car then these will finish it off perfectly. It's certainly worth viewing them and for this amount of money people are welcome to
come and have a trial fit and see how they look on there car (I will keep a firm hold of your keys )
I'm in Derby, collection only obviously.
Link to wheel style:
http://www.imagewheels.co.uk/large_wheel_pages/bps.html
Link to price list
http://www.imagewheels.co.uk/pages/prices_cast.html
Picture of wheels on car:
[Edited on 9/12/13 by Doctor Derek Doctors]
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
posted on 9/12/13 at 08:46 PM |
More pictures:
www.t89.co.uk
callan@t89.co.uk
skippad
posted on 10/12/13 at 09:02 AM |
Nice wheels, interested, all depends on the offset!
Skip
posted on 10/12/13 at 09:26 AM |
Skip
I'll measure them when I get home tonight to see what the offset is like.
They were spec'd for Ford kit car donor use though so fit over The standard Willwood replacement / m16 calipers at the front and Sierra
Cosworth calipers and discs at the back, the pictures were taken with no spacers fitted so you can see how they are just the right width for Locost
wheel arches
www.t89.co.uk
callan@t89.co.uk
carpmart
posted on 10/12/13 at 03:48 PM |
Interested too, but again heavily dependent on offset.
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
posted on 10/12/13 at 08:16 PM |
I measured them tonight, there is no offset stamped into them obviously as they are split rims.
Overall width across the bead is 6" with a 4.5" inner rim and a 1.5" outer.
The measurement from the flange face to the inner edge of the rim is 120mm.
All four wheels are the same.
It would be quite simple and cost effective to buy two new inner or outer pieces to give yourself wider rear wheels if that is what was needed.
I've taken some pictures but can't get the upload to work from my ipad, I can send pictures by e-mail or text though.
www.t89.co.uk
callan@t89.co.uk
skippad
posted on 10/12/13 at 08:22 PM |
I'll check my wheels, and i'll get back to you
carpmart
posted on 10/12/13 at 08:29 PM |
I make this a 44mm offset, is my maths right anyone?
Might be a few mm more than I can handle
'94 MX5 MK1, 1.8
posted on 10/12/13 at 08:38 PM |
Offset(ET) = Backspace(T) - Overall Width(OW)/2
ET=T-(OW/2)
ET=120mm - (150mm/2)
ET=120mm - 75mm
ET=45
Phil
[Edited on 10-12-13 by Hellfire]
posted on 10/12/13 at 08:44 PM |
I measured the 120mm from the inner edge of the rim (which has an extra protective lip) rather than the bead so the offset would be more like ET40.
You could always space them out though, as said they don't fowl the usual locost/Westfield brake/hub/arch set-ups.
www.t89.co.uk
callan@t89.co.uk
carpmart
ET=T-(OW/2)
ET=120mm - 75mm
ET=45
Phil
Thanks Phil!
[Edited on 10/12/13 by carpmart]
'94 MX5 MK1, 1.8
carpmart
posted on 10/12/13 at 08:49 PM |
Final question from me is what does a wheel and tyre weigh please?
'94 MX5 MK1, 1.8
posted on 10/12/13 at 08:59 PM |
Assuming I've understood the measurements correctly, if the backspace is actually 125mm from the mounting face of the wheel to the bead edge,
that would make the wheels ET50
Phil
posted on 10/12/13 at 09:12 PM |
Phil
No the other way round. 115mm from the mounting face to the bead edge making it ET40
www.t89.co.uk
callan@t89.co.uk
Flick
posted on 10/12/13 at 09:13 PM |
u2u.
carpmart
posted on 10/12/13 at 09:15 PM |
ah, ET40 could work then!
'94 MX5 MK1, 1.8
I have no idea, the weights for the wheels nor' tyres are on Image or Yokohama websites and I don't have any scales.
All I say is that they feel lighter than the 13" Compomotive ML's that have replaced them
www.t89.co.uk
callan@t89.co.uk
skippad
posted on 11/12/13 at 05:04 PM |
after measuring and remeasuring and calculating, ive worked out the offset is going to add 20mm each side...
which means front arches will need seriously "re-adjusting" to fit and the rears will rub on heavy cornering.....so sorry they not right
ones for me
daniel mason
posted on 11/12/13 at 05:31 PM |
id highly doubt with a 40mm+ offset they will make it wider! unless your currently running over et60 which id also doubt!
posted on 16/12/13 at 10:33 PM |
Still for sale
www.t89.co.uk
callan@t89.co.uk
CNHSS1
posted on 17/12/13 at 10:18 AM |
I have 15" Image split rims with billet centres, some weights info below
tyre and rim weight comparisons may 08
kumho 205/50x15 V70 list 1B 7" split rim 15.2kg
Kumho 225/50x15 V70 list 1B 8.5" split rim 16.3kg
No tyre 7" split rim 5.6kg
No tyre 8.5" split rim 6.05kg
No tyre 9" split rim 6.2kg
No tyre 10" split rim 6.35kg
Avon 8.5x21.5x15 crossply slick 9" split rim 13.7kg
Avon 10x21.5x15 crossply slick 10" split rim 14.8kg
hope it helps
CNH
posted on 8/1/14 at 08:56 PM |
Lovely wheels and tires still for sale
www.t89.co.uk
callan@t89.co.uk
Stevenbobs
posted on 10/1/14 at 03:43 PM |
DDD,
Can I ask where you got the shark teeth graphics for your nosecone?
Steve.
If it moves and shouldn't..Duct Tape. If it doesn't move and should...WD-40.
posted on 10/1/14 at 08:00 PM |
quote: Originally posted by Stevenbobs
DDD,
Steve.
Painted them with my own free hands, the naked chick on the bonnet was done by an artist friend of mine.
I'll do your nose cone if you by the wheels!
www.t89.co.uk
callan@t89.co.uk
posted on 2/2/14 at 05:49 PM |
Now on eBay to fund a garage roof replacement:
Item no:
331121099301
[Edited on 2/2/14 by Doctor Derek Doctors]
www.t89.co.uk
callan@t89.co.uk
