Hi there, ive got a mini project on the go and im trying to take the underside panels back to bare metal, ive tried paint thinners and a wire brush attachment in a drill which work but is really slow at removing the last layre of paint. Has anyone got any ideas to speed the process up? would parrafin work? Thanks in advance Greg
I used nitromors and it dissolved it quite well, paint scraper took it off then.
Mind your arms tho cos stings
hot air gun if the tanks removed and a paint scrapper
These things are awesome for paint removal, not sure what they're called though
Heat!
Blow lamp and scraper then wire brush, i have done 3 minis back to bare metal on the underside
Screwfix seem to call them preparation wheels,
http://www.screwfix.com/prods/83915/Abrasives/Other-Cutting-Grinding/Surface-Preparation/Preparation-Wheel-115mm
I've used the 'drill' based version and will say that whilst they're good in a drill, they do disintegrate quickly when they find
edges - they like panels, not corners
(also, if you use them on wood be careful as they did a grove quite easily and mark glass quite nicely!)
Get the bulk off with a sharp wood chisel, a bit of heat can help but hot underseal is PAINFUL!
This might make interesting reading for you: http://locostbuilders.co.uk/viewthread.php?tid=149827
It's a long and horrible job, but you'll get there in the end. I found a wire brush 'cup' for a grinder was good for the big
areas and a blow lamp and scraper for the bits that the grinder can't get into. My arms were aching for days but I hope the finished product
will be worth the effort.
Chris
