turbodisplay
posted on 8/11/08 at 02:26 PM |
Locost fire Extinguisher
After running the engine with a oil pipe touching the exhaust, i have decided to fit a fire extinguisher systen. I have found a locost option, just
look in my photos fire, fire1.
Fire extinguisher from wicks £10, pull cable £10, + fitings, 6mm pipework should come to £40.
Darren
blakep82
posted on 8/11/08 at 02:30 PM |
where does the pipe go? i'd worry the pipe would get blocked up?
________________________
ernie
posted on 8/11/08 at 02:46 PM |
Have you seen the mess powder ext. makes? you might be better off with the lifeline unit i and most locost racers use see rally design site
JoaoCaldeira
posted on 8/11/08 at 03:19 PM |
I don't think that is a good idea. You'll have to be pushing the cable to the extingisher work. On a "proper" system you pull
it once and it stays open, so you can get away...
Check our group by here
Joao
Russ-Turner
posted on 8/11/08 at 04:02 PM |
There is a good chance that the one you want can only be operated in an upright position too. Not good.
prawnabie
posted on 8/11/08 at 04:27 PM |
I can vouch for the fact those powder units only work properly upright lol.
turbodisplay
posted on 9/11/08 at 05:04 PM |
Good point R.e. it being momentary, for me i thing it is desirable as you only spray enough to put the fire out, leaving tidy up reduced.
I plan a 2kg dry powder at the front, 1kg for the rear and trans tunnel.
The reason for having a plumbed system, is to operate whilst i am moving, i`m still going to have a 1kg powder in the cockpit anyway.
Re pipe i would use 6mm nylon to allow for flex, then use 6mm coper pipe for heat protection.
I Will mount them upright anyway.
Darren
