Author: Subject: Forming the petrol tank
cjleonard
posted on 12/9/02 at 01:17 PM Reply With Quote
I'm just about to make the tank. I worked out the size (the book seems to be a few diamensions short!). However, I test bent a piece of the metal sheet I'm going to use - the good old fashioned hit it with a hammer approach - and it took some to get it over. This piece was no where near the size of the bit I need to form. So any tips on the best way to form it (read: cheap and easy - I want to avoid buying a tank)
Cheers Chris
theconrodkid
posted on 12/9/02 at 01:54 PM Reply With Quote
I made 2 before i came to my senses and bought one off locodude,sugest you do the same
ewanspence
posted on 12/9/02 at 03:39 PM Reply With Quote
Mine is bullet proof. 1.6mm thick. A bit too much if you ask me but the steel was kicking about.
I parked my Mazda MX6 front wheel on top of a scaffolding plank that was ontop to the steel. Then using a long crow bar I lifted the metal up. Just needed some persuading to finalise all the angles to exactly what I wanted.
Took a couple of hours t fully weld - including making the ends, baffle and slow drain at the outlet.
Ewan.
Visit the MegaGrip site :-
http://www.geocities.com/ewanspence/
chrisg
posted on 12/9/02 at 05:11 PM Reply With Quote
Plasic Tank Man, every time
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Ian Pearson
posted on 12/9/02 at 05:20 PM Reply With Quote
I used a Triumph Spitfire tank. Fits like a dream, and Greengauges sell a sender unit that is externally identical to the Spitfire one. I grafted it onto the old sender unit, and it works like a dream. Tank cost a fiver and the sender was £12.00 ish.
scutter
posted on 12/9/02 at 05:26 PM Reply With Quote
I have an old spirfire tank, free to anyone who wants to collect it at donington on saturday(no sender though)
Ian Pearson
posted on 13/9/02 at 06:21 AM Reply With Quote
I've a spare sender if anyone wants that tank! I'll be at Donington Saturday as well.
James
posted on 13/9/02 at 11:01 AM Reply With Quote
With your job is that the Triumph or Supermarine type?
James
Dunc
posted on 13/9/02 at 11:45 AM Reply With Quote
Locodude, whats the going rate for your tanks and do they come with the holes cut or can I make my own holes in them? How many litres can they hold?
