Daft starter button question!
Jumpy Guy - 1/4/04 at 08:00 AM
If I fit a starter button set-up
whats to stop some idiot passenger pressing it when you're on the move, and ripping the started bendix to bits?
I know this may have a very short answer!!
JoelP - 1/4/04 at 08:16 AM
tell them not to press it!!!!
or, if you is concerned, wire up a relay to interupt the starter, so that it can only start when there is no oil pressure. or something like that...
James - 1/4/04 at 09:09 AM
Fit it to the right-hand side of your steering wheel!
I mean, how often have you had a passenger reach over and turn the keys in your current car?
Or a cut out as Joel said...
[Edited on 1/4/04 by James]
theconrodkid - 1/4/04 at 09:53 AM
depends on how bad/mad a driver you are
phelpsa - 1/4/04 at 11:02 AM
Don't carry a passenger!
Saves weight and money on fuel and tyres.
AND you only have to buy one seat!
blueshift - 1/4/04 at 12:04 PM
Jumpy,
I'm concerned about this too and came up with this circuit: http://locostbuilders.co.uk/viewthread.php?tid=10762
Perhaps you could just use a missile-launch type switch with a flip-up cover?
I prefer idiot-proof though.
VinceGledhill - 8/4/04 at 08:17 AM
Get a message printed around the button that says passenger ejector seat
Hellfire - 8/4/04 at 09:53 AM
I've been giving this one some thought...
As we have a BEC surely it's a feature that the button will not activate when the engine is running... or am I wrong? Afterall, on a bike it's easier to press the button "by accident" and cause damage than on a car!
Mark Allanson - 8/4/04 at 05:13 PM
I thought BEC's were supposed to have a kick start
Mk-Ninja - 8/4/04 at 07:29 PM
I hope not the amount of times I stall it.
Peteff - 8/4/04 at 08:41 PM
My Honda starter will fire in accidentally with the engine running but it doesn't seem to have done it any harm, the few times it has happened, as it is a pre- engaged system.
jmbillings - 18/4/04 at 10:43 AM
Yeah, I think its a bit of a non-problem really, I've never had anyone try and fiddle with the controls in either the locost or a "normal" car. But a cutout circuit should be fairly straightforward as others showed. I worry more about people playing with the immobiliser keypad when on the move as that will cut the ignition
