Craigorypeck
posted on 14/4/11 at 07:59 PM |
Polishing wheels
Got a set of 7j Cobra Slots.
Was gonna sand and shine and buff to a super nice fine finish but there are marks/stains?? in the alloy that dont sand out? Should I continue with the
elbow grease or just smooth them down and just paint them?
Any advice most welcome.. Thanks
Mark Allanson
posted on 14/4/11 at 08:13 PM |
Easy Peasy,
posted on 14/4/11 at 08:15 PM |
Don't suppose you could stick one on a set of scales... often wondered what one of those weighs (yes, sad... I know!).
It's Evolution Baby!
Craigorypeck
posted on 14/4/11 at 08:27 PM |
quote: Originally posted by Mark Allanson
Easy Peasy,
Thats amazin!!! What sort of acid should I get?? Is it stronger volatile stuff or just halfords every day stuff?
I need the spigot to reduce to ford sized hub too.. where did you get them?
Cheers!
Craigorypeck
Will do!
Craigorypeck
posted on 14/4/11 at 08:30 PM |
Am I missing the inserts???
posted on 14/4/11 at 08:31 PM |
Will do!
Cheers!
Steve Hignett
posted on 14/4/11 at 08:38 PM |
That's not the easy peasy way above...
The link below is the easy peasy way... (Although it's quite a tiresome video!)
http://www.youtube.com/watch?v=LxxG4A4OgHI
Mark Allanson
posted on 14/4/11 at 08:45 PM |
You are missing hardened inserts and special sleeved nuts, you can get the nuts and centre caps from midland wheels, the inserts are available on
ebay. Midland Wheels and
Ebay
I just weighted a 6x13 ET13 Wolfrace and it is 4.5Kgs
I used Autoglym wheel cleaner (I manage a bodyshop so have access to the pro stuff), but your alloys are much better than mine were so I would get
straight in with the 240g, or try wet and dry lubricated with WD40 or similar.
Mark Allanson
posted on 14/4/11 at 08:51 PM |
Looks like a good way of ending up with 6 fingers and a file embedded in your groin!
posted on 14/4/11 at 08:58 PM |
Slotmag?
Blimey that's light!
Craigorypeck
posted on 14/4/11 at 09:12 PM |
Are cobra wheels the same as wolfrace??? ie the inserts will be the same fitment?? These arrived today and its all new to me so sorry for the silly
Q!
What about spigots too?
Also need longer studs I think... Without the inserts there's only a few threads grip..
[Edited on 14/4/11 by Craigorypeck]
Steve Hignett
posted on 15/4/11 at 07:46 AM |
I know! Fun, right!!!
Craigorypeck
posted on 19/4/11 at 10:39 PM |
Got all the bits from mistertee.co.uk
on 1200 wet and dry now.. looks ace! whats the best way to keep them shining without having to take them off every month and autosol them?? Lacquer?
Wax? Clear powder coat?
Promai Joe
posted on 23/4/11 at 08:11 AM |
I needed some spigot rings and used the following company, there were helpful and fast delivery, would recommend them.
MotorSpeed
