Author: Subject: Nippon Denso alternator connections
Steve Lovelock
posted on 21/4/08 at 04:28 PM Reply With Quote
Hello,
I have a Nippon Denso alternator but can't work out the connections to it from my wiring loom. I am using a Vicki Green loom from Robin Hood and it has three wires to the alternator. One is a very heavy duty brown wire which I have attached as in the picture. The other two are brown and brown / yellow. Any idea on how I can connect them?
Regards
Steve Lovelock
posted on 21/4/08 at 04:31 PM Reply With Quote
mitch2b
posted on 21/4/08 at 05:05 PM Reply With Quote
Hi Steve
hopefull this will help
http://community.rhocar.org/index.php?showtopic=18584
half way down page theres a link to another post with diagrams on
Mitch
Steve Lovelock
posted on 21/4/08 at 07:43 PM Reply With Quote
Thanks Mitch, will try that.
muzchap
posted on 21/4/08 at 08:39 PM Reply With Quote
Steve, if it doesn't U2U me - I wired one of these up and have the details somewhere
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Steve Lovelock
posted on 22/4/08 at 08:09 PM Reply With Quote
Well I followed the link to Robin Hood and realised that I shouldn't have had a permanent live and that I needed to power the lead from the dashboard lamp. Sorted those and then ran the engine and it worked perfectly, thanks.
mitch2b
posted on 23/4/08 at 05:30 AM Reply With Quote
looks like you had the same problem has me Steve, cost me a new regulator
cant understand why one wires perminant live though?, looks like another VGreen trait !!!!
Mitch
posted on 23/4/08 at 06:50 AM Reply With Quote
helpful except I can't view the LH forum photos.
B+ is main charge out.
what is A,B and C for?
Steve Lovelock
posted on 23/4/08 at 10:24 AM Reply With Quote
Here are the pictures.
I used the b & c terminals, not sure what way round but it would only work one way.
Mitch, not really sure if the charging part is working yet as I haven't tested that. The ignition light goes out at the charging circuit is showing 14 Volts when the engine is running and also not running. As there was no difference I was a little curious but I could only test it at tick over so I will look into it further later on. Rescued attachment Denso2.gif
Steve Lovelock
posted on 23/4/08 at 10:25 AM Reply With Quote
Laikathedog
posted on 29/10/16 at 10:04 PM Reply With Quote
hi. i have the three wire denso
i have found a diagram that shows that
a - swtiched live
b - live from battery post
c - to warning lamp
but it does not switch off the lamp or charge
[Edited on 29/10/16 by Laikathedog]
posted on 29/10/16 at 10:43 PM Reply With Quote
Rover Mazda and Honda used that model in the late 1990's early 2000's
One of the small terminnals ISTR the centre but not 100% sure is a square wave duty cycle signal to the ecu it is not required for everything to work.
Denso Alt Duty Cycle Idle
The other small terminnals are warning lamp and battery voltage sensing.
posted on 30/10/16 at 02:23 PM Reply With Quote
Correction --- alternator rear view
Denso
Denso
