New Topic New Reply
Author: Subject: reverse gear!!
clu
posted on 7/8/11 at 12:21 PM Reply With Quote
reverse gear!!
Hi y'all I'm building a mk indy delux kitcar and have just perchased the reverse gear kit from mk.. which contains a starter motor & a machined sprocket with 2 solid bars with 1 end internaly threaded! i've looked through most pages in the forums but found nowt has anyone got any pictures or info on where 2 mount it and how?? plz help
james h
posted on 7/8/11 at 02:17 PM Reply With Quote
I believe the sprocket attaches to the front of the diff, sandwiched by the prop - as for the starter, I'm not too sure where that goes. There may be brackets on the tunnel for it if you specified reverse gear when you ordered the kit.
I know that's not too descriptive, but I hope it points you in the right direction!
James
fimi7
posted on 7/8/11 at 03:03 PM Reply With Quote
Check out this link
http://locostbuilders.co.uk/viewthread.php?tid=110570
--- Ali
clu
posted on 8/8/11 at 05:09 PM Reply With Quote
reverse gear
aaa sweet thank u just what im looking 4 cheers woohoo
andersmartensson
posted on 9/8/11 at 07:56 AM Reply With Quote
Make sure you fit it properly they thend to twist and than slip on the sprocket.
with less interesting results
if you are in control - you arn't going fast enough.
New Topic New Reply
