Lola
posted on 26/2/12 at 04:46 PM |
Door Treshold
Hi there Can any one help?
I need some trim to go over the door treshold on my locost.
What trim do peple normally use and where can i git it.
Chippy
posted on 26/2/12 at 04:58 PM |
The world is your oyster there, all sorts have been used, mine is done with a couple of wood mouldings, (varnished), others have used vinyl covered
padded bits fastened on, alloy strip, you name it. Cheers Ray
macc man
posted on 26/2/12 at 05:00 PM |
I made mine from rigid foam used for protecting worktops in transit (30 mm). Covered in vinyl and glued in position, See archive pics. Cost nothing
and looks good.
jacko
posted on 26/2/12 at 05:16 PM |
I made alloy U channels bent to the shape and trimmed with padding under the trim
Dash / wind deflector
[Edited on 26/2/12 by jacko]
Daddylonglegs
posted on 26/2/12 at 06:05 PM |
Mine's made from uPVC edging strip. It came rounded on one edge and I cut to width then rounded it to match on the cut side. Sprayed black,
looks fine to me.
