Poll: Wiping ones bottom ? [View Results]
Right handed but use left.
Right handed and use right.
Left handed but use right.
Left handed and use left.
I use either.
Dont bother.......ewwwwwww.
<<  1    2  >>
Author: Subject: Wiping ones bottom ?
Jon Ison
posted on 16/6/11 at 07:41 AM Reply With Quote
After hurting my right arm, (I,m left handed) and thinking how the heck am I going to wipe ones bottom I realised I always use my right hand, lucky then but what does everyone else do ?
posted on 16/6/11 at 07:57 AM Reply With Quote
You're married and still wipe your own? Try using the "wrong hand" to brush your teeth as well. When I injured my shoulder I had to do everything left handed and learnt to cope quite adequately, at first everything was a challenge though.
posted on 16/6/11 at 08:00 AM Reply With Quote
You didn't ask the crucial "front to back" or "back to front" technique.
FWIW, I don't wipe my bum as I don't poop. Apparently it's just me and Her Majesty who don't!
It's Evolution Baby!
posted on 16/6/11 at 08:05 AM Reply With Quote
Or like Rimmer, one up one down and one to polish
posted on 16/6/11 at 08:09 AM Reply With Quote
Is that why he was called Rimmer?
Humbug
posted on 16/6/11 at 08:13 AM Reply With Quote
Eh? There's no option for using toilet paper instead of using a hand
(the old ones are the best!)
posted on 16/6/11 at 08:18 AM Reply With Quote
As a clean freak, I was most upset with the facilities in my first office in the rural Balkans. A hole in the floor, no bog-roll, and an old soft drinks bottle that was filled with tap water.
No soap and the bottle had finger-smudges round it!
There was no mistaking when Scotty-boy needed to go as he was seen walking up the corridor with his own loo-roll and bar of soap! The locals thought I was very odd
MK9R
posted on 16/6/11 at 08:35 AM Reply With Quote
you've missed off "drag yourself across the carpet"
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
jollygreengiant
posted on 16/6/11 at 08:38 AM Reply With Quote
A relative of mine recently broke BOTH arms after falling down a flight of stairs, resulting in both arms in plaster. Its a good job his wife loved him.
wilkingj
Get a Bidet!
Then when your hand / arm gets better you can use the Bidet to wash you feet. Its a lot easier than ballancing on one leg with your foot in the sink
Best Regards
Geoff
http://www.v8viento.co.uk
r1_pete
posted on 16/6/11 at 08:42 AM Reply With Quote
You mean you dont employ a 'Groom of the Stool'
kipper
posted on 16/6/11 at 08:57 AM Reply With Quote
Last time I was In Tokyo,I went to see sumo wrestling ,I asked the question ,how does the big guy reach his bottm to give it a wipe, answer was they have an assistant to do that.
Not a job I would like.
Denis.
Where did that go?
whitestu
posted on 16/6/11 at 09:00 AM Reply With Quote
This is just too off topic - please delete!
NigeEss
posted on 16/6/11 at 09:25 AM Reply With Quote
Have you got a dog ?
corrado vr6
posted on 16/6/11 at 10:06 AM Reply With Quote
What No Key hole surgery!
http://r1indy7.wordpress.com/
balidey
posted on 16/6/11 at 10:22 AM Reply With Quote
Depends what you eat, you can get away without 'needing' to wipe.
Dutch bears have terrible skin due to their clogged paws
mangogrooveworkshop
posted on 16/6/11 at 10:39 AM Reply With Quote
In Africa they just use leaves in a longdrop toilet
Like to see the buggers use the nettle leaves you get here
posted on 16/6/11 at 10:47 AM Reply With Quote
I guess that whoever does your laundry would disagree!
balidey
posted on 16/6/11 at 10:54 AM Reply With Quote
Three words...
Buy
Brown
Pants
posted on 16/6/11 at 10:58 AM Reply With Quote
TheGiantTribble
posted on 16/6/11 at 11:34 AM Reply With Quote
Out in Mongolia, the local goat herders use fist sized stones/pebbles
apparently it's wise to spend a few minutes looking on the ground for a rounded one rather than one with sharp edges
norfolkluego
posted on 16/6/11 at 11:49 AM Reply With Quote
Bit of 38mm water hose shoved up the er... required apperture, nothing touches the sides (of you), job done, no need to wash.
Pop the 'used' water hose in the dishwasher*, jobs a goodun, ready for next time.
* N.B. A parts washer makes a suitable alternative
Dick Axtell
posted on 16/6/11 at 02:18 PM Reply With Quote
Which is exactly what one does in Kuala Lumpur, in their non-European bogatrines. Best remember to hire a towel beforehand, otherwise you have to "drip-dry"!
Angel Acevedo
posted on 16/6/11 at 02:31 PM Reply With Quote
Theres also the Japanese way (Or at least how we call it in Mexico)
Grab paper cone, remove and save tip (bottom), Insert finger through small hole, clean surface, grab cone with other hand (oops, method not suitable for single handed use) squeeze fecal matter off finger, dispose of soiled cone, use cone tip to clean nail crevices....
Done... (in Gordons Ramsay´s accent)
posted on 16/6/11 at 02:37 PM Reply With Quote
Uuuuurrrggghhhhh!
<<  1    2  >>
