MikeR
posted on 22/11/23 at 01:23 PM |
Do you actually know what HP the engine came with from the factory? Or are you trusting the published HP and speed figures?
cliftyhanger
posted on 23/11/23 at 09:27 AM |
I think most engines from teh factory were not as good as teh published figures. And depending on year, teh engines were tested without ancillaries
(water pump, dynamo etc) making a sizeable difference.
And on top of that, you have not checked teh cam timing. It may not be a tooth out, but the chain may have stretched etc, and the cam lobes may have
wear
The only thing to do if you really want to find out is an engine strip and a fresh build. Probably replacing a lot of stuff in the process, with teh
risks associated with new/remanufactured stuff.
Plan b is to not worry too much!
smart51
posted on 23/11/23 at 10:28 AM |
quote: Originally posted by Prof_Cook
I am lacking technical skills in BHP to MPH correlation and grateful for any clarification on what the theoretical relationship is.
But assuming 22.6 BHP gives a 67 MPH max speed. The most you are getting is 62 MPH (this is 92.5% of 67MPH), then assuming a linear relationship this
(92.5% of max power) suggests about 20.9 BHP so 1.7 BHP is what is missing.
[Edited on 21-11-23 by Prof_Cook]
The power needed by the car is a little bit involved, but not impossible to estimate. Given my engineering background, I've made a spreadsheet
model of it.
RW horsepower is the sum of 3 parts:
a constant * speed cubed (in m/s) * coefficient of drag * frontal area. All the numbers are on the internet.
weight of the car * g * speed in m/s * coefficient of friction of the tyres (always hard to get the right number).
an amount of power to keep the engine running, and pump fuel and oil etc. A total guess, but a small number.
Flywheel horsepower is RW horsepower * efficiency of the transmisssion
My model is easily calibrated by the quoted power and top speed of various engine sizes in the car. The 17.5 BHP car from the early 60s would do 59
MPH. The 18.0 BHP car from the late 60s would do 60 MPH.
smart51
posted on 23/11/23 at 10:31 AM |
My car was deliberately throttled from the factory by fitting a tiny carburettor. The quoted figure was 18 BHP. The same engine was used on the Fiat
126 with the bigger carburettor with a quoted 22.6 BHP. My car had the bigger carb fitted.
smart51
posted on 23/11/23 at 10:36 AM |
wear
You have come to the same three conclusions as me, which is reassuring. Plan b is where my head is.
I'm worryingly tempted to go down the rabbit hole though.
I'm trying to think of a halfway house. Currently that's in the form of getting a DTI and measuring the vale opening and closing points WRT
crank angle to see if the cam is advanced or retarded. I only need to remove the rocker cover for that.
cliftyhanger
posted on 23/11/23 at 10:54 AM |
quote: Originally posted by smart51
You have come to the same three conclusions as me, which is reassuring. Plan b is where my head is. I'm worryingly tempted to go down the
rabbit hole though.
Ah. Are you 100% the engines are the same head/compression ratio and cam?
smart51
posted on 23/11/23 at 11:37 AM |
rabbit hole though.
I'm pretty sure the head is the same. There were only 4, the 500cc head, the 600cc head, the 650cc head and the Panda 30 head.
Nobody can tell me about the camshaft though. The early cars are well documented. My car was the runout model, which was built along side the Fiat
126. They increased the size of the engine for the 126, didn't want to make 2 engines, so fitted the big engine to the 500 as well. But they
restricted the engine on the 500 so that it wasn't faster than the new car. So far as anyone knows, the only change was fitting the tiny carb
from the 1950s 500.
But, they may have changed the cam too. Nobody seems to know. The 500 had 3 cams in its life, though one was only used for the first few months of
production. The 126 had a slightly different cam. It is possible that Fiat used one of the older cams in my car, just to hold it back a bit.
19/50 50/19 1957
09/70 50/19 1957/8 and 1960 - 65
25/51 64/12 Sport and 1965 - 71
25/56 66/16 126
There's not a lot to choose between them. The late 60s cars made 0.5 BHP more by using the "sport" cam.
smart51
posted on 23/11/23 at 11:43 AM |
A small correction. The compression test on my engine (when done hot and I remembered to use WOT) gave 120 PSI on cylinder 1 and 130 PSI on cylinder
2. In theory it should be 110 PSI but no-one seems concerned about slightly high numbers.
Mr Whippy
posted on 23/11/23 at 12:39 PM |
Add a go faster stripe, that will give you at least an extra 10bhp ![](/images//smilies/smile.gif)
posted on 2/2/24 at 07:36 PM |
it is not linear, drag goes up by the square of the speed.
so about 16% difference
Aerodynamic drag increases with the square of speed, power required increases with the cube of speed.
