reverse gear!!
clu - 7/8/11 at 12:21 PM
Hi y'all I'm building a mk indy delux kitcar and have just perchased the reverse gear kit from mk.. which contains a starter motor & a machined sprocket with 2 solid bars with 1 end internaly threaded! i've looked through most pages in the forums but found nowt has anyone got any pictures or info on where 2 mount it and how?? plz help
james h - 7/8/11 at 02:17 PM
I believe the sprocket attaches to the front of the diff, sandwiched by the prop - as for the starter, I'm not too sure where that goes. There may be brackets on the tunnel for it if you specified reverse gear when you ordered the kit.
I know that's not too descriptive, but I hope it points you in the right direction!
James
fimi7 - 7/8/11 at 03:03 PM
Check out this link
http://locostbuilders.co.uk/viewthread.php?tid=110570
clu - 8/8/11 at 05:09 PM
aaa sweet thank u just what im looking 4 cheers woohoo
andersmartensson - 9/8/11 at 07:56 AM
Make sure you fit it properly they thend to twist and than slip on the sprocket.
with less interesting results
