Author: Subject: good conneciton to savage switches
andrew_s
posted on 9/5/10 at 09:49 AM Reply With Quote
hi
just getting round to wiring up my savage switches - what have people found to be the best way to connect to these switches. i bought some small red insulated female blades, but these just feel a bit loose even after some further crimping, i dont fancy soldering them all on, so wonder if theres a better option. thanks.
daniel mason
posted on 9/5/10 at 09:52 AM Reply With Quote
you can get different blade sizes! what size blades are on your red lugs?
can you double the wires over in the crimps?
[Edited on 9/5/10 by daniel mason]
bassett
posted on 9/5/10 at 09:56 AM Reply With Quote
Got mine from maplins(exact size), these do feel cheap and nasty and the insulating plastic moves around but so far after a year of driving they have stayed on fine.
[Edited on 9/5/10 by bassett]
YQUSTA
posted on 9/5/10 at 10:11 AM Reply With Quote
Same as above.
iirc you will find them in the speaker part of the store as the were the speaker terminals.
If you still find them a little loose just get the pliers on the end of them to tighten them up a little.
"If in doubt flat out"
Colin McRae
RazMan
posted on 9/5/10 at 10:12 AM Reply With Quote
Red crimps are really your only option and although they are a bit chunky for the job mine have been trouble free for 3 years now. They do benefit from a little tweak with pliers to make them a really snug fit.
Raz
Danozeman
posted on 9/5/10 at 10:17 AM Reply With Quote
MIne were on using the smallest red terminals. stayed on fine. The switch fell apart but the terminals were still on.
Dan
Steve Hignett
posted on 9/5/10 at 10:28 AM Reply With Quote
I've bought about a thousand or so over the last few years and there is a massive difference in quality - This is a case of get what you pay for IMO - Of course it also doesn't hurt to have them in your hand when you're buying rather than off of ebay etc...
YQUSTA
posted on 9/5/10 at 10:29 AM Reply With Quote
Maplin crimps
I am pretty sure these are the ones I used
Colin McRae
Hugh_
posted on 9/5/10 at 11:27 AM Reply With Quote
I got some tiny uninsulated female spade connectors at Stoneleigh last year, so have been using them.
TimC
posted on 9/5/10 at 02:27 PM Reply With Quote
Yep, hate insulated crimps. Almost always use uninsulated and then heatshrink as required.
andrew_s
posted on 9/5/10 at 03:24 PM Reply With Quote
thanks for all the replies, i will try the maplin uninsulated ones and heat shrink a bit of tubing on to be sure, sounds ideal, cheers for the help, getting there ver slowly. does anyone have a suggested switch layout for putting eveything on the tunnel, is there any specific do's and donts for sva?
bigfoot4616
posted on 9/5/10 at 07:08 PM Reply With Quote
the red crimps i found the correct size where very poor quality so i got the correct size non-insulated crimps and got a soft plastic insulator for it
andrew_s
posted on 11/5/10 at 07:56 AM Reply With Quote
thanks for that, thats the way i will go
