Author: Subject: Sierra Box
Hammy360
posted on 23/11/10 at 12:28 PM Reply With Quote
Sierra Box
I've just bought a 1990 Ford Sierra as my donor, how do I find out the gearbox type that it has? Also I havent decided between the MK Indy or the Tiger Avon, any thoughts? I'll be ordering my kit this week so your advice is appreciated
flak monkey
posted on 23/11/10 at 12:34 PM Reply With Quote
Reverse position will tell you.
Up and to the left is a type 9
Down and to the right is an MT75.
Sera
http://www.motosera.com
loggyboy
posted on 23/11/10 at 12:55 PM Reply With Quote
Or look underneath to see if the bell housing is integral to the box, (MT75 is integral, type 9 is bolted)
mikeb
posted on 23/11/10 at 02:07 PM Reply With Quote
You could also order a comprehensive kit from saturn based on the haynes roaster, its another option to add to mix and very similar i believe to the MK.
turnipfarmer
posted on 23/11/10 at 02:41 PM Reply With Quote
Check with the kit mfr before committing yourself. There aren't too many chassis will take the MT75 box, but most will handle the type 9
DJT
posted on 23/11/10 at 11:19 PM Reply With Quote
I'm not sure on what donor parts the MK Indy uses, but if you are going Avon (like me), then make sure that you can source all the required donor parts. The gearbox is one of the harder ones - hopefully you've got a type-9. The cortina uprights are getting rare too.
You can see a picture of each gearbox here:
MT75
Type-9
Good luck!
Mix
posted on 23/11/10 at 11:30 PM Reply With Quote
Hi
Just to clarify - the MT75 box pictured in the post above is the 4WD version, the 2WD one does not have the power take off at the rear and is therefore narrower.
Regards Mick
