<<  1    2  >>
Author: Subject: IVA retest issues - before / after.
adithorp
posted on 25/1/11 at 01:22 PM Reply With Quote
When mine was SVAd, the tester (Dave at Chadderton) mentioned my column clampbolt wasn't locked. I told him it had loctight like every Ford on the road and he passed it but said it might be worth sticking a lock nut on the end just for peace of mind.
http://jpsc.org.uk/forum/
designer
posted on 25/1/11 at 01:26 PM Reply With Quote
Bias bar - no threads protruding from bolt
Steering column extension bolts - looks bad with the cut off nut. Can't you reverse to make it look better?
Diff. bolts - way too long and not secure.
Camber locknuts - Not secure and no thread protruding from nut.
Wheelnuts - longer studs required as no thread protruding from nut
Mix
posted on 25/1/11 at 05:38 PM Reply With Quote
Hi
I think this is an excellent post - it has prompted constructive criticism based on the informative photographic content and will assist others in the future I'm sure.
Agree with the comments on the wheel nuts, (getting longer studs), and the steering column joint can be better sorted by the use of spacers and longer bolts rather than grinding down nylocs, (my opinion).
Regards Mick
stevegough
posted on 27/1/11 at 08:24 PM Reply With Quote
Originally posted by Mix
Hi
Regards Mick
Nice comment, 'Mr Mix with the lips' - thank you.
After a bit of agonising - time running short etc, and taking the collective advice from you guys on here, I have gone and changed the 40mm studs for some 63mm ones would have been better in - between but the only other size I could find was a 47mm - not really enough.
Picture?
Naturally. Bit long now - do you think it might be a problem tomorrow? ( retest at 2:30 ).
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
stevegough
posted on 27/1/11 at 08:27 PM Reply With Quote
By the way, its my birthday (21 again!) - want to see the cake my daughter - in - law made for me?
I was pretty chuffed - tasted nice, too!
Luego Locost C20XE.
Rallye_Mark
posted on 27/1/11 at 09:11 PM Reply With Quote
Not enough thread protrusion on the cake wheel studs.
stevegough
posted on 28/1/11 at 08:35 AM Reply With Quote
Don't worry, it'll be eaten long before the IVA man sees it!
Luego Locost C20XE.
welderman
posted on 28/1/11 at 09:03 AM Reply With Quote
When is the big IVA day
Thank's, Joe
I don't stalk people
stevegough
posted on 29/1/11 at 07:13 PM Reply With Quote
er- yesterday!
Luego Locost C20XE.
<<  1    2  >>
