<<  1    2  >>
Author: Subject: Make your own Half Hood
NickMK
posted on 30/6/11 at 07:14 PM Reply With Quote
Originally posted by stevegough
Originally posted by NickMK
Originally posted by YQUSTA
Rail Supports
HTH
Brilliant. Thank you!
Or even 20 SPRING CLIPS TOOL STORAGE TERRY 9MM 3/8' £1.79 PACK | eBay UK
Maybe.. Thank you.
Really I want the bar to sit on the inner edge of the roll bar and windscreen and to be able to put some tension into the pole.
So I think the rail supports might work, but would love for them to spring locking mechanism to stop the bar lifting out the top.
I might just have to modify the ones from Screwfix and just add a little tap of sprung steel.
NickMK
posted on 30/6/11 at 07:24 PM Reply With Quote
Just finished off adding Velcro to the rear straps, stops them flapping
stevegough
posted on 30/6/11 at 07:29 PM Reply With Quote
Could do with something like velcro on the wife's hair!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
NickMK
posted on 30/6/11 at 07:45 PM Reply With Quote
I take it your wife doesn't read this website
Humbug
posted on 2/7/11 at 04:28 PM Reply With Quote
Sorry - only just seen your repy to my question about a hoop, and it looks like you've solved the problem now.
Here is a link to my hood thread, and this is a pic with teh hood on:
The hoop is in three parts and fixes to the roll bar; originally I put some threaded bar into tapped holes. Later I put rivnuts in the roll bar, but you get the idea.
Simon
NickMK
posted on 26/7/11 at 12:09 PM Reply With Quote
The half hood had its first real test a couple of weekends ago.
I drove down to North Devon in the pouring rain, 2 1/2 hour journey M4 then A361 and came out the other end 98% dry
The most impressive bit was that you don't get a single bit of spray coming in from behind and having no back means that there is plenty of ventilation so no steamy windows
The only water came in from under the Side Screens but have now put a fix in place.
Also I'm glad to see this post has been useful to others http://locostbuilders.co.uk/forum/4/viewthread.php?tid=158625 Great job Myke
swanny
posted on 26/7/11 at 12:32 PM Reply With Quote
looks great.
as a possible alternative rear fixing we made a loop in the fabric and inserted some 5mm bar across the width of the roof. this was then pulled on by two straps and provides even tension evenly across the width.
paul
<<  1    2  >>
