Author: Subject: zx9r turbo conversion 130bhp to 250bhp +
mk-indy-zx9r
posted on 17/6/12 at 12:32 AM Reply With Quote
its now on ebay -
ZX9R ZX9 NINJA mk indy kit car stuart taylor tiger b6 westfield caterham locost | eBay
any questions or advice fire away im here to help
maccmike
posted on 17/6/12 at 12:47 AM Reply With Quote
hehehe nice
Ben_Copeland
posted on 17/6/12 at 07:01 AM Reply With Quote
Please read the rules about multiple posting...
http://www.locostbuilders.co.uk/forum/42/viewthread.php?tid=114067
Third point, basically your pushing other posts off the front page by multiple posting
Ben
Locost Map on Google Maps
Enter Your Details Here
ReMan
posted on 17/6/12 at 09:18 AM Reply With Quote
Groovy
What turbo is it?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
jossey
posted on 17/6/12 at 10:27 AM Reply With Quote
Love it
David Johnson
Bare
posted on 17/6/12 at 03:29 PM Reply With Quote
Yeah.. 250 Hp
This is interesting from a few posts back
I did not have much luck with my zx10r turbo conversion, first engine did 200 miles before it melted a piston and second engine bent a rod, make sure you fit upgraded rods and pistons as the standard ones are made of plasticine ok in a bike, but can't take the extra stress in a car.
Also fit a good intercooler.
You need to speak to Sean "Indybird" on here, he bought my car from me in the end, and did a good job of getting it running well in the end, but don't expect it to last too long, I know Sean sold the car on, and believe the new owner blew it up at Oulton park, I think if I was doing it all again I would start with a Busa.
Here's a video of my first start up.
http://www.youtube.com/watch?v=MHzSCh1k6U4&feature=my_favorites&list=FLFVhYyJ8l-7tyAOq6potitQ
Here's a video of Seans when he had worked his majic on the engine
http://www.youtube.com/watch?v=yqV3ipH-1X0&feature=results_main&playnext=1&list=PLACED24E4B74C743D
Here's a picture of the turbo and titainum manifold
[/img]
[Edited on 17/6/12 by Bare]
Big CC Racing
posted on 18/6/12 at 10:07 PM Reply With Quote
Originally posted by mk-indy-zx9r
its now on ebay -
250hp @ 10psi is as likely as me being good looking by 10pm.
mk-indy-zx9r
posted on 22/6/12 at 12:39 AM Reply With Quote
Originally posted by Bare
Yeah.. 250 Hp
[/img]
was yours not set up correctly ?
melted piston is normaly due to a poor fuel mix & ing on boost of witch will cause a very high egt (exhaust gas temps) & det.
the bent rod can be a cause of many things main cause is again high heat temps and to much torque. this can be rectified through the set up.
the zx10 is fuel injection so would need to have needed the fueling and ing setting up to suit,were as a blow through on a carb can stay standerd as the more boost is used it just forces in the correct leval of fuel.
if set up correctly its a very safe conversion, i would recomend low boost on a stock engine, but if you wish to run higher boost, concider lowing the compression (either low comp pistons or thicker base gasket spacer) also uprate the head bolts and a metal headgasket.
i used a vems air fuel ratio gauge and egt gauge to keep my eye on any problems and to make sure it was set up running safe.
there are loads of turbocharged bike engines in kitcars that have be problem free for 1000`s of miles.
any questions are welcome if more info is required.
mk-indy-zx9r
posted on 22/6/12 at 12:41 AM Reply With Quote
Originally posted by ReMan
Groovy
What turbo is it?
vf23 from a impreza wrx comes onto full boost around 6,000 rpm
mk-indy-zx9r
posted on 22/6/12 at 12:46 AM Reply With Quote
its now on ebay -
mine was using z1000 pistons and quite a few other mods, but in a std zx9r E1 i would probley say 230bhp @15psi
would only recommend you run a max of 8psi to be safe still be around the 200bhp mark if not a little more.
would you not agree big cc?
