Author: Subject: do they remove body parts
leeswesty
posted on 20/6/12 at 05:31 PM Reply With Quote
HI can any tell me do they remove the nosecone or any other parts of body also the nut covers as to get my nosecone off i have to turn the lights to the side and they will need resetting also the nut covers are a bit slack so i put a blob of silicone in them to keep them on
Live life to the max
rb968
posted on 20/6/12 at 05:47 PM Reply With Quote
He didn't remove the nosecone on my IVA test. My understanding is they might ask you take off "removable" panels but he didn't even ask me to remove the boot cover and just inspected everything from underneath.
Rich
posted on 20/6/12 at 06:02 PM Reply With Quote
Not usually, no. If you're worried though, take lots of photos of the inaccessible places on the car just in case.
Phil
leeswesty
posted on 20/6/12 at 06:09 PM Reply With Quote
Thanks guys
rb968
As above......especially seat belt mounting points and welds if hidden behind panels. I had to show photos of those in the tunnel.
Rich
daniel mason
posted on 20/6/12 at 06:22 PM Reply With Quote
i had to remove tunnel top and boot pannel on mine last month!
Coopz
posted on 20/6/12 at 06:27 PM Reply With Quote
Not on mine...As already said take pictures, he didn't check the pictures either.
mark chandler
posted on 20/6/12 at 06:28 PM Reply With Quote
In Romania they do for cash, what you offering?
coyoteboy
posted on 20/6/12 at 06:58 PM Reply With Quote
For what purpose, did you have sufficient documentation to show it and they still wanted to see it?
leeswesty
posted on 20/6/12 at 07:16 PM Reply With Quote
I hope not as carpets all stuck down with spray glue and my fuel filler it in top of boot box
johnwilders
posted on 20/6/12 at 08:15 PM Reply With Quote
I had stuck some of my nut caps on with silicone, I just explained that I couldn’t get them all the right size
leeswesty
posted on 21/6/12 at 06:48 AM Reply With Quote
Was they ok with that also why dose it take 5 hrs to do a test
coyoteboy
posted on 21/6/12 at 08:39 AM Reply With Quote
It takes ~45 minutes to do a basic MOT. The IVA tests a hell of a lot more in more detail (just check out the what, 400(?) page manual). They don't just rock the lights up to a device that shows the beam pattern, they measure their positions relative to other parts, the check mirrors give visibility they should, they need to check metal is thick enough in places etc. The MOT is a quick jog over the bare essentials, the IVA is a marathon to prove that what you've created isn't going to kill someone in normal use or in a crash. And £100 per hour for a highly skilled tester to check you're not going to kill someone once before it gets on the road is fairly good deal to my mind
[Edited on 21/6/12 by coyoteboy]
