<<  1    2  >>
Author: Subject: Halfrauds - What's a cotter pin?
posted on 20/11/12 at 08:15 AM Reply With Quote
Originally posted by Peteff
A different type of cotter pin used to hold the handbrake cable into the lever on back axles. It was like a nail with a hole drilled in for a split pin to go through.
That sounds like a Clevis pin to me Pete!
posted on 20/11/12 at 08:47 AM Reply With Quote
That's a Clevis Pin because it fits into a Cleviis
flibble
posted on 20/11/12 at 08:59 AM Reply With Quote
So what are the little doodaads called that resemble a very small tube with a slit down one side (from end to end)?. Needed one a few weeks ago and no idea what they're called!
Macbeast
posted on 20/11/12 at 09:37 AM Reply With Quote
A Roll pin ?
coyoteboy
posted on 20/11/12 at 09:40 AM Reply With Quote
Big Wasa (and Mark Chandler) are right, Coyoteboy obviously works at Halfrauds They are now secured by having a square, tapered bottom bracket shaft, with a matching square tapered hole in the pedal crank, the ends of the shaft have a fine-pitch thread into which a bolt is screwed to retain the crank, this is recessed into the body of the pedal, then finished off with a plastic cap. See pic on the link ---> linky The exception to this is BMXs which have a one-piece crank.
No, I just have picked up americanisms it seems Plus in many years of engineering have never had to resort to a cotter pin
Oh, and now who works in halfords - square taper is old hat
coyoteboy
posted on 20/11/12 at 09:45 AM Reply With Quote
FWIW I have just found this etymology online:
"The terms cotter and "cotter pin" are sometimes used interchangeably, although they have different functions. Basically a cotter holds parts together and a "cotter pin" holds the cotter in its place."
Which is the way I'd always assumed it to be, but who knows
ChrisL
posted on 20/11/12 at 09:50 AM Reply With Quote
ebay for fronts and mx-5 parts for rears, re cotter pins, I'm in the wedge bolt thing camp
<<  1    2  >>
