Author: Subject: MK Indy nose cone... radiator choice.
cps13
posted on 14/3/13 at 01:34 PM Reply With Quote
My car fits MK Indy body work at the front (I think this is the same size as Ron Champion?!) I bought a polo radiator, the wider one of the two and it is too wide. Does anybody know if the narrower one will fit? i.e. SEAT AROSA 1997-2004 / VW LUPO / POLO 1994-2001 RADIATOR NEW - 2 YEAR WARRANTY | eBay
Or what rads have you fitted? Its for a silvertop locost.
Thanks all
Custardpants
posted on 14/3/13 at 01:42 PM Reply With Quote
I run the updated alloy rad MK sells and frankly it is too large, In addition to my engine electric pump barely ticking over I had to add blanking to the radiator - it is too big IMO and the car runs too cool. Have you thought about trying a hayabusa radiator?
Ben_Copeland
posted on 14/3/13 at 02:00 PM Reply With Quote
It's the narrower one you want. There's loads of people with them
Ben
Locost Map on Google Maps
Enter Your Details Here
posted on 14/3/13 at 03:36 PM Reply With Quote
Manufactures fit thermostats and by-pass connections for a reason the thermostat controls the cylinder head temperature within quite close limits and the by-pass keeps the bottom of the cylinders warm and avoids the formation of hot or cold spots.
renetom
posted on 14/3/13 at 04:43 PM Reply With Quote
Hi we used the small polo rad & it fits fine
The only thing was we had to cut off the small
plastic outlet on the top left hand side, just araldited a
self tapper in the hole
good luck
René
Waterworks R1 Indy
Waterworks R1 Indy
Custardpants
posted on 14/3/13 at 04:45 PM Reply With Quote
Entirely true, but doesn't it make sense to fit a smaller lighter radiator to save weight rather than fit one which is too big, and then rely on the thermostat to do all the work. Perhaps a CEC might not have any issues though....
