Author: Subject: How big is your fuel tank?
Davidthomas
posted on 20/3/14 at 07:56 PM Reply With Quote
Can anyone tell me how much fuel their tanks can hold??
jacko
posted on 20/3/14 at 08:02 PM Reply With Quote
35lts
home made tank
35l fuel tank over diff
jacko
daniel mason
posted on 20/3/14 at 08:19 PM Reply With Quote
4 litres
must keep thinking power/weight
mark chandler
posted on 20/3/14 at 08:23 PM Reply With Quote
20 litres
posted on 20/3/14 at 08:29 PM Reply With Quote
53L..
Plastic Fuel Tank 53 Litres - OSCULATI
Dint pay that much tho, search the marine webby's..
adithorp
posted on 20/3/14 at 08:32 PM Reply With Quote
Just over 6 gallons... and I've squeezed 200 miles out of that.
http://jpsc.org.uk/forum/
gaz_gaz
posted on 20/3/14 at 08:50 PM Reply With Quote
60 litres
omega0684
posted on 20/3/14 at 09:15 PM Reply With Quote
8.5 gallons
mccsp
posted on 20/3/14 at 09:17 PM Reply With Quote
It's not how big it is but how you use it that matters
Approx 25l + 2l swirl pot. When the ticker pump gets loud I am down to a couple of useable litres.
Why do it the easy way, when I can do things my way!
cerbera
posted on 20/3/14 at 09:29 PM Reply With Quote
Thats summat I've worked out recently. 30 litres.
adithorp
posted on 20/3/14 at 09:45 PM Reply With Quote
Who worked out?
jollygreengiant
posted on 20/3/14 at 10:02 PM Reply With Quote
Not entirely sure, what I do know is that the FIRST time I filled it (on the way to SVA about 5 years ago) it cost nearly £70 to fill it. I think I worked it out at about 11.5 - 12 gallons. Enough for a 240 mile round trip.
Here you go as per body of text 11.82 gallons. linky to original posting
[Edited on 20/3/14 by jollygreengiant]
steve m
posted on 20/3/14 at 10:54 PM Reply With Quote
first one about 4.5 gallons,
second one 6.5 gallons, much better !
DavidM
posted on 20/3/14 at 11:22 PM Reply With Quote
Mine is 6 gallons.
Proportion is Everything
unijacko67
posted on 21/3/14 at 12:20 AM Reply With Quote
5.5 Gallons.
http://www.kittenkitcar.co.uk
snapper
posted on 21/3/14 at 06:54 AM Reply With Quote
35 Litre with 2L swirl
But getting 35 Litre in is a mission so normally expect 30 Litre
I eat to survive
I drink to forget
cerbera
posted on 21/3/14 at 06:59 AM Reply With Quote
Who worked out?
All right then... We :-p
Oddified
posted on 21/3/14 at 08:44 AM Reply With Quote
6.5 gallons / 30 litres in mine. Range all depends on how it's driven, between 60 and 200+ miles.
Ian
[Edited on 21/3/14 by Oddified]
FuryRebuild
I've been building my own composite fuel tank for my fury - it's been a complex and drawn out process but if you fancy a bit of a read, here it is.
I've designed it to run down the transmission tunnel (IRS, so no inconvenient prop movement). I'm also making a fully structural transmission tunnel replacement, which will have composite prop-catchers in (Aramid) so I have full protection between prop and tank. I'm not duly concerned - most of the wayward energy is angular if a prop shears so the catchers don't need to absorb a lot while it spins down.
www.furyrebuild.co.uk
killerferret666
posted on 21/3/14 at 10:27 AM Reply With Quote
12 Gallons.
I have the space and id like to be able to use it on long runs and with a 2litre turbo engine a good size tank was needed.
Building DDR GT4
Miami Gt4 Blog - Click Here
renetom
posted on 21/3/14 at 10:50 AM Reply With Quote
6.5 gallons
