Author: Subject: whats the name of this that Im trying to describe
killerferret666
posted on 2/9/14 at 08:12 PM Reply With Quote
you take a wire cable....loop it back on itself ...to errrr... create a loop. Hold them together.
Then a metal clip is put round it and crimped tight, so your left with a loop at the end of the wire thats strong and wont come loose.
Without knowing what these pieces of metal are called, searching for crimp, clip and other names brings back all sorts!
thanks
Building DDR GT4
Miami Gt4 Blog - Click Here
Slimy38
posted on 2/9/14 at 08:19 PM Reply With Quote
Wire loop crimp seems to bring back some relevant Google results, including this;
http://www.savacable.com/pages/prod_02_04.html
Talon Motorsport
I think this is what they are called ....
http://www.youtube.com/watch?v=Evcsj1gx1CE
Staple balls
posted on 2/9/14 at 08:20 PM Reply With Quote
Ferrules
iank
posted on 2/9/14 at 08:22 PM Reply With Quote
This kind of thing? http://www.tecni-cable.co.uk/Products/Wire-Clamp-Rope-Grips-Cable-Clips-Clamps
Best ranges usually tend to come from chandlers.
Anonymous
killerferret666
posted on 2/9/14 at 08:26 PM Reply With Quote
Both get credit, Although Staple Balls, nailed the correct name of it! Cheers guys
Originally posted by Staple balls
Ferrules
Building DDR GT4
brum_gustavo
posted on 3/9/14 at 03:17 AM Reply With Quote
Build diary: http://gustavobrum.wordpress.com/
AndyW
posted on 3/9/14 at 06:38 AM Reply With Quote
What are you trying to make?
I used the loop a piece of wire trick when making a teather for my fuel cap. I used the bottom part of a electrical terminal, the part you crimp round a cable when making the end if a wire. I just cut of the "spade part", removed the plastic outer and had a ready made crimp to create a hoop that once crimped was secure.
Theshed
posted on 3/9/14 at 08:25 AM Reply With Quote
You can get them here if you want...along with lots of other lovely expensive things..
http://www.lasaero.com/site/products/category?id=K02EMF1BB
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 3/9/14 at 07:53 PM Reply With Quote
Originally posted by brum_gustavo
Depending on the size of the wire rope and its use, I have found the ally ferrules very useful, You can make a jig to squeeze them closed and it will give good strength. The one labelled as open spelter is a different kettle of fish and is 100% the strength of the rope itself but it involves a lot of work and the need to pour hot white metal into the fitting... Really only worth while over 3/4" ropes.....
The Black Flash
posted on 3/9/14 at 09:19 PM Reply With Quote
I'll bet it's for the boot lid, to stop it opening too far as that was one of his IVA fail points.
If it's any use, for my bonnet stays I made the wire loop, with a long return (6 inches or so) and used heat shrink over it to hold it together. Wasn't sure if it'd be strong enough but it turns out that it is, more than. Your lid might be heavier of course, but if you're after a quick -n- easy just for the test, it might do.
I managed not to get any decent pics, here's one for the idea:
