Author: Subject: Threaded inserts for plastic
simonrh
posted on 30/9/14 at 08:57 PM Reply With Quote
I have just been converting my quantum to run a polo radiator and it is all now together. I have had it on and off so many times that the m6 threads I tapped into the bosses on the polo rad to mount it are beginning to feel a bit "soft" when I do them up now.
Anyone ever used anything like this before?
http://www.theinsertcompany.com/brass_vaned_expansion_inserts_for_plastic.phpIt
would give me a metal-metal thread that would tolerate being undone fairly regularly and secure what is there.
iank
posted on 30/9/14 at 09:14 PM Reply With Quote
They're regularly used in plastic boxes for exactly this purpose. Only problem with them really is buying them in small enough quantities. RS sell them in bags of 100.
Anonymous
renetom
posted on 1/10/14 at 07:25 AM Reply With Quote
Self tapper
Slimy38
posted on 1/10/14 at 08:18 AM Reply With Quote
Originally posted by renetom
Self tapper
I thought self tappers were even less tolerant of being reused, almost to the point of being 'single use'?
loggyboy
posted on 1/10/14 at 08:42 AM Reply With Quote
Self tapers are ok if you reinsert the screw/bolt carefully so that you reuse the first tapped thread every time. (ie wind the screw backwards till it clicks in to the thread).
Mistral Motorsport
steve m
posted on 1/10/14 at 09:34 AM Reply With Quote
I had a similar problem with my polo rad, so I araldited some threaded bar into the holes, and used nylocks and washers on the other end
its been like that for a few years now
steve
pewe
posted on 1/10/14 at 11:12 AM Reply With Quote
JB weld into the hole, screw in the fixing with a single wrap of cling-film around it, leave to cure then tighten later - simples.
Cheers, Pewe10
Dingz
posted on 1/10/14 at 04:57 PM Reply With Quote
You can get something that looks like a nutsert but has a rubber body so you get a bit of damping too. Not sure where from though
went on and on.
simonrh
posted on 1/10/14 at 05:37 PM Reply With Quote
I actually have studs in there at the moment anyway so the plan for now is to try a set of inserts that are "press in" that I bought from flebay today. If they don't work as the manufacturer intended then I will do as suggested above and below and bond it all in with epoxy.
brettuk
posted on 6/10/14 at 01:55 PM Reply With Quote
Simon, I would recommended you checkout http://www.fasteningsolutionsuk.com/ also, they are a decent supplier of inserts.
I have used them for a while now, they offer good shipping also for bulk orders.
