Author: Subject: Throttle body "socks"
Plunky
posted on 15/4/15 at 02:27 PM Reply With Quote
Does anyone know where i can get some foam throttle body covers from for sensible money?
Thanks,
Liam
mcerd1
posted on 15/4/15 at 02:47 PM Reply With Quote
Don't bother, they'll kill your power, get a sausage filter or an airbox instead!
karlak
posted on 15/4/15 at 03:01 PM Reply With Quote
Talking of sausage filters.
Do they need oiling ? If so, which oil is recommended please.
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
Ugg10
posted on 15/4/15 at 03:39 PM Reply With Quote
Got these from Ramair off ebay, they often have some on buy-it-now but others on auction. Think I picked these up for £25 for the pair IIRC.
I am hoping these may be a bit better than the individual ones as there is a bit more space inside.
Example here - http://www.ebay.co.uk/itm/2-x-RAMAIR-Carb-Sock-Air-Filters-Double-Trumpet-Weber-DCOE-Dellorto-DHLA-CS-901-/391111853956?pt=LH_DefaultDomain_3&hash =item5b10154784
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
posted on 15/4/15 at 06:29 PM Reply With Quote
Yes they do. They need washing and oiling quite frequently, depending on the type & location of driving you do.
Filter oil is pretty good to use.
Phil
Jenko
posted on 15/4/15 at 08:19 PM Reply With Quote
I used the ram air from ebay, loads of different sizes, and fantastic value. Agree with advice though, try if possible to avoid the individual sock filters and try to squeeze on a sausage filter.
MY BLOG - http://westfieldv8.blogspot.co.uk/
austin man
posted on 15/4/15 at 08:52 PM Reply With Quote
Use the Ramair on my zx9 carbs
Dopdog
posted on 16/4/15 at 01:37 AM Reply With Quote
Or even better stick a dead chicken in the end of them and get a better airflow, do as above you know you want to.
Unless you love chickens of course😊
Plunky
posted on 16/4/15 at 01:29 PM Reply With Quote
thanks for the advice!
Will measure up and try and find one of the twin style filters to fit
Paul Turner
posted on 20/4/15 at 10:15 AM Reply With Quote
I used a Ram Air "sausage" filter over my twin Jenvey bodies to replace my 15 year old K & N's which were still in perfect condition but lacked the space for decent length trumpets (60mm max). Looked good and appeared to work OK, Plenty of space for decent sized trumpets (80mm). Kept it cleaned and oiled on a regular basis.
But after 3 years of summer use the foam started to crumble. Ram Air were not interested simply saying that the foam should not be exposed to sunlight.
The K & N's are back on now and with the help of some extension pieces I have pretty decent induction length (about 90mm from the end of the TB). Still look perfect and are now 22 years old.
So if your filter is exposed (like it is on many Sevens) IMHO forget foam.
