Author: Subject: Tyre wear on the Nordschleife
Hakuraa
posted on 2/8/15 at 11:48 AM Reply With Quote
Hi chaps,
Can anyone give me an indication of how abrasive the Nordschleife please. I am booked on both days of the DN13 event and so need to know if my Toyo R888's will last for both days (currently about 4mm left) or whether I should fit a new set just for this event, previous experience is in someone else's road car for a few laps.
Car is a MAC#1 Worx ZX10, so with driver is going to be in the 600-620Kg region - no I am not build like an F1 driver - geometry set up for track/fast road use.
Andy.
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Hakuraa 's Aim
bi22le
posted on 2/8/15 at 03:26 PM Reply With Quote
Do you drive like an F1 driver though? !
I saw no more excessive wear both times i went but i didn't drive it hard.
Track conditions are good so expect no more wear than a normal track day.
Is DN13 a public day or closed circuit? I would expect you to do no more that 10 laps a day on a public day due to queues and stoppages.
10 X 2 X 11 (mins) = 220 mins of track time max.
If your getting to the legal limit then stop! I only did 4 laps a day i think.
Please read my ring story:
Hakuraa
posted on 2/8/15 at 05:00 PM Reply With Quote
Not even in my head, there are far better drivers than me!
DN13 is a closed track day for both days, so hopefully plenty of track time, with only 150 cars allowed out on track at once it will a mile away from a public day. Fuel consumption and tank size should let me stay out for 3 laps at a time as it is purely the Nordschleife circuit not the VLN layout, however the elevation changes and higher average speeds may change this plan.
jps
posted on 2/8/15 at 06:24 PM Reply With Quote
(I say this with ZERO practical experience, although if I'm wrong I'd be interested to know why)...
Isn't that area know for changeable weather/the track so big it may be dry at one part/wet elsewhere?
I would have assumed that, even with tyres with poor water clearing properties, you'd want to have as much tread depth as possible, incase you end up on a damp bit?
Or put another way, not worth the risk given a potential benefit and especially as it's a consumable that you'll replace regardless sooner or later?
twybrow
posted on 2/8/15 at 06:47 PM Reply With Quote
What he said! The ring is made up of lots of different surfaces, in all manner of environments, so if it were me, I would change them and keep your current tyres for a track day or two closer to home.
750mc
posted on 2/8/15 at 07:07 PM Reply With Quote
+1.
Hell of a place. Get the best gear you can on it.
austin man
posted on 2/8/15 at 08:37 PM Reply With Quote
some really good sections and some concrete if you nailing it then you will see wear as said the weather tends to change at the turn of a hat
Hakuraa
posted on 13/8/15 at 07:46 PM Reply With Quote
Thanks for the replies and advice, new tyres ordered, roll on September
