New Topic New Reply
Author: Subject: Chassis bracing options
F1SJL
posted on 23/8/15 at 11:18 AM Reply With Quote
Hi all
Advice needed.
I would like to put a 4 into 1 manifold on my pinto but want it to come out of the lower side panel not the bonnet.
The only routing I can work out will foul the side panel diagonal brace.
Could I remove this and brace another way?
Ideas please.
Adamirish
posted on 23/8/15 at 12:11 PM Reply With Quote
Mine comes out of the side panel, albeit the opposite side. It was made to miss this chassis brace and comes out 2 inches rearward of the chassis brace. May be easier to make the exhaust fit the chassis rather than the chassis fit the exhaust.
MK Indy 1700 Xflow
mark chandler
posted on 23/8/15 at 04:05 PM Reply With Quote
Turn the single diagonal into a Y to make the space you need, you are after making triangles within the rectangular area.
F1SJL
posted on 23/8/15 at 04:18 PM Reply With Quote
Yeah that's what I figured. Triangles give structure.
Would you advise doing both sides to to maintain balance?
Badger_McLetcher
posted on 3/9/15 at 09:25 PM Reply With Quote
Of any interest\use? I wouldn't worry overly about trying to keep both sides balanced if you go the Y-brace route - stick with the diagonal on the other side.
If disfunction is a function, then I must be some kind of genius.
posted on 3/9/15 at 09:30 PM Reply With Quote
Put the engine in the back so the exhaust can exit without needing any mods to the chassis..
And, you can extend your roll cage down to the suspension to stiffen everything up!
New Topic New Reply
