Author: Subject: Which Zetec throttle body for GBS plenum
Hammy360
posted on 28/9/16 at 11:45 AM Reply With Quote
Hi
I tried to fit the one from the 2 litre mondeo but the backing plate is too thick. I've heard it mentioned that you need one from a Focus but which one? I assume a 2 litre Focus blacktop? Also do I need to retain my current TPS to match my Oem loom and ecu?
Cheers guys
Hammy
mcerd1
posted on 28/9/16 at 12:31 PM Reply With Quote
I've no idea which one fits the GBS plenum, but as far as I know all the mk1 focus's (98-04) use the same version of the 1.8/2.0 zetec's (i.e. the last version aka: blacktop or Zetec-R or focus zetec)
if the 2.0 is anything like my 1.8 its a nasty cheap lump of plastic
[Edited on 28/9/2016 by mcerd1]
SteveRST
posted on 28/9/16 at 02:27 PM Reply With Quote
If OEM ecu then I guess it will be expecting the TPS to be outputting resistance values within a certain range as you open/close the throttle. I *think* it's likely that the silver-top TPS would output same values as a Focus one, but test it with a multimeter on the bench to be sure though.
Yeah Focus/Blacktop throttle body is what is intended. As you say, it has a thinner mounting base.
I used a 2.0 Mk1 Mondeo one though. Drilled the holes bigger and then used 4 sleeve nuts to secure the throttle body to the screw threads on GBS plenum.
Hammy360
posted on 28/9/16 at 04:43 PM Reply With Quote
Good shout on the sleeved nuts! Btw its a blacktop I have. Thanks for the tip and photos! Gotta love this site!
Hammy
AndyW
posted on 28/9/16 at 04:45 PM Reply With Quote
hammy
I have a blacktop Tb the plastic one, let me know if its any use. I'm still in Belgium so will sort pics of exhaust when back
Ta
Hammy360
posted on 28/9/16 at 04:48 PM Reply With Quote
OK mate, give us a shout when you are back Andy
Hammy
Hammy360
posted on 6/10/16 at 06:56 PM Reply With Quote
Thanks mate,
I am doing the same as you and have ordered the sleeves. Cheers for the tip!
Hammy
