Author: Subject: Sierra Master Cylinder
posted on 31/3/21 at 11:11 AM Reply With Quote
The MK Indy has just failed it's annual MOT and needs a new brake master cylinder. To avoid having to replace the brake pipes, I wondered if anyone has a Sierra Master Cylinder laying around. It's the one that has two connections from the front and one on the rear. I've searched the usual places but am not having much luck. Any help would be hugely appreciated
Phil
Mr Whippy
posted on 31/3/21 at 11:23 AM Reply With Quote
there are plenty seal kits available, dead easy, one circlip and it all pops out. Just google - sierra master cylinder seal kit, so many to choose from
I prefer the ones that come with the whole thing, pistons etc rather than just the seals. Then you know it all fits together. Use loads of brake fluid to assemble.
[Edited on 31/3/21 by Mr Whippy]
posted on 31/3/21 at 11:53 AM Reply With Quote
Just looking for a like for like replacement to get it back on the road ASAP.
posted on 31/3/21 at 11:56 AM Reply With Quote
Maybe a daft question but does the 'search' function on this forum not work anymore?
roadrunner
posted on 31/3/21 at 12:23 PM Reply With Quote
Hi Phil.
No is the answer.
If you use your Google search using "Locostbuilders" in the search it works quite well.
Brad
roadrunner
posted on 31/3/21 at 12:31 PM Reply With Quote
Have you looked on Ebay.
Linky
[Edited on 31/3/21 by roadrunner]
Mr Whippy
posted on 31/3/21 at 12:52 PM Reply With Quote
tonnes on ebay etc, you could get the kit in the next couple of days, 1hr job on the road again...
I can't get anything out the search function. I'd get genuine seals from whatever manufacture made the cylinder. Too risky getting cheap parts that end up writing the car off or worse to save a few £££a
posted on 31/3/21 at 01:00 PM Reply With Quote
I thought there would be tonnes on eBay too but unfortunately I can't find one that's like for like.
The one I have has two vertical connections on the front. One pointing up at approx 45 degrees and one pointing down, plus a rear connection.
roadrunner
posted on 31/3/21 at 01:02 PM Reply With Quote
The brake lines are quite flexible. Wont you be able to manipulate them to fit.
posted on 31/3/21 at 02:51 PM Reply With Quote
That might be my only option if I can't find an identical master cylinder.....
Russell
posted on 31/3/21 at 04:47 PM Reply With Quote
Best to whip the cylinder off the car and check the bore size before you buy either seals or a replacement. Many look the same on the outside but might be 19mm-ish or 22mm-ish bore (sorry, can't remember the exact values).
I'm a bilingual illiterate. I can't read in two languages.
wowblaauw
posted on 31/3/21 at 05:28 PM Reply With Quote
Hi, I might be able to help out. If you can u2 me your email address I’ll forward you mine so I can send images of several I have.
Craig
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, wine in the other, body thoroughly used up, totally worn out and screaming...
Damn, What a ride!!"
posted on 31/3/21 at 08:42 PM Reply With Quote
Thanks for the offer! You have U2U
