posted on 11/10/22 at 05:53 PM |
I gave up reading halfway through, but my solution would be to attach 50mm kingspan to the actual roof timbers. Seal together with adhesive foam
(expanding foam that doesn't expand much). Then just board onto the existing ceiling timbers with shims as required to correct levels. I did my
roof with a ventilated dry ridge, so air could still circulate behind the insulation.
I also built my extension with 50mm kingspan rather than wool, and I'm still wearing a tee shirt with no heating on. 😎
posted on 12/10/22 at 07:22 AM |
Good to hear of others not having turned the heating on yet
Energy price rises aside we're still OK here without the heating on (Hampshire). Yesterday was chuffing chilly outside when I went to catch the
bus to work at 06:30. Frost on the cars, huffy breath, but in the house we're OK.
I can see it coming, but I'm also tight so I'll be waiting until I'm feeling properly cold!
posted on 12/10/22 at 08:52 PM |
Absolutely Nick!
SteveWalker
posted on 12/10/22 at 10:16 PM |
I've never understood "turning the heating on". That's the point of thermostats. If it's cold enough the heating will come on
and if it's not, it won't.
In our case, I've gone the extra mile and every room, plus the hot water tank, has its own timer/thermostat and its own motorised valve. So, the
system is on all year, with the boiler heating the hot water tank twice a day and each room heating if it is in the correct time span and colder than
its set-point.
posted on 14/10/22 at 09:09 AM |
its set-point.
You're right, our heating is thermostat controlled and effectively on all the time. Combi boiler so it heats hot water on demand. The central
heating only kicks in when the temperature in the house drops below the thermostat setting.
A couple of the rads (those that have been fitted/replaced since we bought the hosue) have individual controls.
coyoteboy
posted on 14/10/22 at 11:16 AM |
Indeed, my house has per-rad TRVs and a programmable room stat with 7 time windows for different temps, and the heating remains on all year.
But you'd be surprised by the number of people I know (and my old rental flat) have just a timer.
[Edited on 14/10/22 by coyoteboy]
