prawnabie
posted on 12/7/08 at 08:31 PM |
My first question!
Hi guys
I have already introduced myself in the general chit chat part of the forum, but I have a question now!
I haven't drove my car much as i only collected it last week and intend on rebuilding it before any major use, but when I drive over small
drains, potholes etc, the back of the car feels like there is no suspension at all!
I have have a look at the rear axle etc and the "nose" of the diff seems much too close to the chassis at the end of the transmission
tunnel than i would like - to the point that i think it is hitting the chassis and causing the bottoming out I mentioned above.
I have thought about raising the spring seat on the shocks, but the design of them beggars belief!!
Here is a bad pic of the axle under no load - you can see how close it is and where it has been rubbing the chassis
http://farm4.static.flickr.com/3043/2662164188_e0c2c6f5a9.jpg?v=0
here is a pic of the shocker bottom - anybody seen this type of shocker before?
http://farm4.static.flickr.com/3246/2662165260_4504035fba.jpg?v=0
A new full set of coil overs is already on the list as i have zeemerrides up front . Can anybody suggest a set and spring ratings?
[Edited on 12/7/08 by prawnabie]
RichardK
posted on 12/7/08 at 08:36 PM |
It a motocycle shocker but off what sorry dunno.
1000 posts !
Regards
Rich
Gallery updated 11/01/2011
mr henderson
posted on 12/7/08 at 08:46 PM |
ou need to know the unfitted length as well as the spring rate. A good start would be to measure the springs that are on there now
John
posted on 12/7/08 at 09:32 PM |
That shocker looks like the type fitted to old 80's twin shock Z1000's and the like...
prawnabie
posted on 13/7/08 at 12:25 AM |
Hi
ive just looked at the shocker and the spring seemed very coilbound with no load in the car.
There was also about 10mm of travel before the bumpstop was reached!!
the sticker on the spring said 120lbs!!! surely these are way to weak for the rear weight of a locost???
pbura
posted on 13/7/08 at 02:09 AM |
Easy way:
- Remove shocks and measure open and closed eye-to-eye lengths.
- Call a supplier of popular shocks for Locosts and order shocks of similar lengths with springs, 300# front, 175# rear. Edit: These may be a little
stout for an X-flow, see http://locostbuilders.co.uk/viewthread.php?tid=93196
Hard way, but less of a crapshoot:
- Block up the car, remove shocks, and measure total wheel travel front and rear. Also note minimum and maximum shock length. While you're at
it, measure front and rear unsprung weights.
- Make a judgment about where you'd like your ride height to be and how your wheel travel will be split between bump and droop. Consider
having 15-25mm of rake from back to front to allow for the occasional heavy payload and to improve air flow under the car.
- Block the car at desired ride height and measure what the shock length must be at rest and at 1", 2", and 3" of wheel bump.
- Using pieces of tubing with drilled holes to simulate shocks at your ride height, load the car with a normal payload (you, possibly a passenger or
half a passenger, half tank of fuel) and measure front and rear weights.
- Report back here with the data, and forum members will be able to suggest some shock and spring specs.
[Edited on 13/7/08 by pbura]
Pete
