<<  5    6    7    8    9    10    11  >>
Author: Subject: Duratec install progress - sump construction underway
Stuart_B
posted on 3/2/10 at 07:01 PM Reply With Quote
i so which i could carry on with my install, as i was going to use a eaton supercharging in a few years time.
nice work david, i will love to this a some shows, and meet you would be good as well.
stuart
flak monkey
posted on 3/2/10 at 10:41 PM Reply With Quote
Should be at Stoneleigh, if all goes to plan....and it doesnt go bang on the way!
Sera
http://www.motosera.com
goaty
posted on 4/2/10 at 07:47 AM Reply With Quote
optimistic
I am the same with mine, hoping the fist time it turns over all gos well.
Another one for you.....Do you knwo what starter will work with my flywheel set up?
would a duratec ka one work?
cheers dave
flak monkey
posted on 4/2/10 at 07:51 AM Reply With Quote
What do you have again? I cant remember.
There are essentially 2 different starters, the mondeo one and the St150 one.
The St150 sits closer to the block as the flywheel is slightly smaller than the mondeo one.
I *think* all the aftermarket steel flywheels use the mondeo one.
The Ka engine is totally different.
Sera
goaty
posted on 4/2/10 at 07:55 AM Reply With Quote
titan flywheel so i need to find a mondeo one, or some smaller equivilant if there is one.
cheers david
ps, charger bracket is made so i can now look at mounting into the chassis to work out the alternator mounting....should be fun...lol
goaty
posted on 4/2/10 at 10:54 AM Reply With Quote
any news on your rad and coooler yet? mine wont be ready for another month yet lol
cant wait to see what they will come out like
matt.c
posted on 4/2/10 at 08:03 PM Reply With Quote
Do i need to get my helmet and gloves out yet?
Is it finished yet?
flak monkey
posted on 5/2/10 at 09:40 PM Reply With Quote
The rad is done, intercooler will be sorted early next week hopefully.
Was hoping the prop would be ready this week so I could finally fit the engine, but sadly its not finished yet.
Looks like it will be next weekend for the final fitment now
Sera
flak monkey
posted on 7/2/10 at 03:30 PM Reply With Quote
Very little progress this week. Crap week at work hasnt really put me in the best frame of mind for working on the car.
Did get a few little jobs done however...
Beefed up the steering column support, painted and fitted the column properly too. Seems much better now
Steering column support
Column finished
Column finished
Fitted the oil filter housing from Raceline, was expecting it until next week, but there we go Fingers crossed the filter will clear the chassis.
Oil filter housing
Oil filter housing
Bolted down the battery on the top of the footwell. Amazingly small compared to the old one, and will allow me to mount the header tank above it and still clear the bonnet. This will leave me more room to fit the swirl pot and oil tank for the rotrex up on the footwells too.
Battery and tanks
Battery and tanks
GRS also sent over some pics of the radiator which is nearly finished, just need to fit the bleed connection on the top of the right hand tank. Its basically the same frontal area as a polo radiator, but is a twin tube core and the pipes are designed to clear the chassis better. They will be making the intercooler this week, so all being well I should have that next weekend....
Hopefully things will go better next weekend and I can get the engine mounts beefed up and the engine finally mounted in the chassis.
Sera
FASTdan
posted on 10/2/10 at 01:25 PM Reply With Quote
All looking good - what do you do out of interest? I only ask as I assume design engineer perhaps? given the cad and general engineering knowhow.
flak monkey
posted on 10/2/10 at 01:59 PM Reply With Quote
I work as a project engineer, but am also getting more involved in production management more and more every day it seems....
The last couple of weeks have been hell as we had a load of machines down, but things seem to be picking up now *touch wood*
Sera
dlatch
posted on 10/2/10 at 04:20 PM Reply With Quote
that rad looks absolutley perfect
i dread to think but how much?
FASTdan
posted on 10/2/10 at 09:45 PM Reply With Quote
Same here (project engineer). What do you make/design/build? We do special purpose machinery for the food and process industry (tobacco, pharmaceuticals etc).
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
flak monkey
posted on 10/2/10 at 10:03 PM Reply With Quote
I work for a specialist bearing company. The projects are varied, I usually get involved in procuring new machinery rather than the site improvement stuff. That includes everything from selecting the kit, justifying it, sorting tooling, capability trials, training, and long term support to the shop floor. The machinery can be anything from £2k wash tanks to £250k+ grinders.
I also am responsible for the technical side of 6 manufacturing areas (3 turning (upto around 500mm dia) 2 grinding and hardturning (internal and external) and the raw material cut off). If any of the areas have any technical problems they come and see me... so its pretty varied, but when machines are out of action it becomes a nightmare.
Anyway as this is starting to sound like a CV....
GRS have just sent some more piccies of the radiator and intercooler over for my perusal Looks like its coming on well. Theres just the tight 90deg 50mm tubes to weld on by the looks of it. The intercooler is 50mm core, and bolts to the front of the radiator. I will fit some strips top and bottom to force any air that goes through the intercooler to pass through the radiator too...unless GRS beat me to it
And no its not cheap But should be more than adequate!
Sera
flak monkey
posted on 13/2/10 at 09:10 PM Reply With Quote
Made a little more progress yesterday, and dropped the engine and gearbox in finally tonight. Need to torque the bellhouing bolts, but access is easy.
Welded in some additional plates on the chassis, the intention being that tomorrow I will be spending the day beefing up the engine mounts by adding in another tube and rubber mount on each one.
Mount plates 1
Mount plates 1
Mount plates 2
Mount plates 2
Drilled the hole in the bulkhead for the clutch master cylinder. Should give a pedal ratio of around 4.5:1 which should give a light enough pedal and progressive clutch hopefully! Though yet to try it out...
Also made a new brake pipe to avoid the master cylinder and tidy it all up a bit as I never was happy with the original pipe work.
Clutch cylinder mount and new
Got the new prop fitted as well. Went for a heavy duty one from Dunning and Fairbank. Highly recommended, quick turn around (1 week) and beat everyone else on price
New prop 1
New prop 1
Thankfully theres loads of clearance between the supercharger and the column now, around 15mm all around.
Column clearance
Column clearance
Fitted the oil filter as well so I know how much room I have for the engine mount modifications. Thankfully there's plenty of room around there.
Oil filter fitted
Oil filter fitted
Also looks like my intercooler and rad is nearly finished by the pics I have just had from GRS
Sera
goaty
posted on 14/2/10 at 10:20 AM Reply With Quote
looks very good, how tall is the cooler ocmplete with the pipe connections, they look like they poke up quite high.....worried abotu how tight it will be.
And i got issues fitting my engine, it dont fit in the bay...lol. Moving some bits of chassis as we speak
you dont realise how tight these engine bays are till you try...lol
Yours is looking very good now david, keep up with the pics etc, wish i'd done the same
flak monkey
posted on 14/2/10 at 07:09 PM Reply With Quote
The dimensions are as in the drawings, think I posted them earlier in this thread somewhere...
Glad I didnt have to move any chassis rails!
Finished off the engine mounts today after concerns they werent up to the job. Hopefully now they should take the stick!
This pic shows the angle of the mounts from the front
Finished engine mounts 1
Passenger side
Finished engine mounts 4
Drivers side
Finished engine mounts 3
The rad and intercooler are finished too and should be here next week
Next weekends jobs are mounting the oil cooler for the supercharger. Adding in an additional bolt bracket on the supercharger bracket which will increase the stiffness of the mount considerably. Mounting the swirl pot and header tank. Connecting up the clutch and checking for leaks. Starting to suss out the wiring and pipework for the engine bay.
Sera
Stuart_B
posted on 14/2/10 at 07:23 PM Reply With Quote
that looks awesome david,
great work
stuart
goaty
posted on 14/2/10 at 08:36 PM Reply With Quote
that does look amazing. cant wait for mine
flak monkey
posted on 17/2/10 at 09:57 PM Reply With Quote
Modded the throttle bodies tonight to give me a point to take a MAP signal from each. Oddly most off the shelf throttle bodies seem to only come with TPS as standard and no option for map.
Nerve racking drilling into several hundred quids worth of throttle bodies, but there we go...
Fitted an M5 threaded, 4mm hose tail into each port. Sealed in with Loctite 542 thread sealant.
Once modded they were fitted up again, and hopefully wont be coming off again any time soon Throttle stops all set and locked off too to cosworths recommended base settings.
Throttle body mods 1
Throttle body mods 2
Throttle body mods 3
Throttle body mods 14
Throttle body mods 5
Sera
goaty
posted on 17/2/10 at 10:28 PM Reply With Quote
looks briliant, not sure if i woudl be brave enough..lol. Are you going to run them to a little break tank or just tee them straight to the map sensor??
Some seem to use a little tank to loose any chance of pulses....
wont be long till she runs
flak monkey
posted on 18/2/10 at 08:53 PM Reply With Quote
I will probably run them to a small tank as I need to split the MAP signal between the ECU, fuel pressure regulator and dump valve...
Getting a bit worried about progress at the moment, as I need to get enough time in to get it mapped on the road before stoneleigh otherwise I'll be in the tintop
Sera
Steve Hignett
posted on 18/2/10 at 08:58 PM Reply With Quote
Originally posted by flak monkeyotherwise I'll be in the tintop
Don't even think it...
goaty
posted on 18/2/10 at 09:42 PM Reply With Quote
lol, i am sure you will make it, unfortunately i am garunteed to be in tin top, bt am awiting a peek at yours
matt.c
posted on 18/2/10 at 10:35 PM Reply With Quote
Great progress flak. Have you thought about fitting a full fire extinguisher system? Wouldnt want a small leak to end in disaster!
