<<  2    3    4    5  >>
Author: Subject: C20XE overheating problems.
Ben_Copeland
posted on 6/7/13 at 09:33 PM Reply With Quote
Originally posted by spaximus
this is probably a silly suggestion, but have you got the belts correctly installed. I did once see a car where they guy had done away with the tensioners, as it looked cool, but had then made the water pump run the wrong way.
All standard and timed up correctly.
Ben
Locost Map on Google Maps
Enter Your Details Here
davidimurray
posted on 6/7/13 at 09:36 PM Reply With Quote
I had similar problems with my pinto when I first plumbed it up. Mine would over heat and the fan would not kick in. Checked the thermostat out of the car and it worked fine. My system was basically plumbed as a loop with the expansion tank tee'd in.
What I found was that the system was basically running against the deadhead that was formed by the thermostat. The water in the pipes and radiator were slowly heating up, but there was no flow around the system and hence the thermostat never got hot enough to open, meanwhile the water in the block just sat there getting hot.
My solution was that there was a small outlet on the thermostat elbow. I added an 8mm bypass line from the thermostat to the top of the expansion tank, this gives a constant flow of water over the thermostat and makes sure it opens.
Before making this mod my car wouldn't idle without overheating, now it will sit happily being revved away without any problem.
Can you try running without the thermostat just as a test. That will at least tell you if it is an issue with the thermostat.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Ben_Copeland
posted on 6/7/13 at 09:47 PM Reply With Quote
No thermostat isnt recommended, but i think i'll try it anyway. Cant get any worse !
Ben
rdodger
posted on 6/7/13 at 10:07 PM Reply With Quote
Don't you have a bypass Ben? Doesn't it bypass around the heater circuit?
Ben_Copeland
posted on 6/7/13 at 10:12 PM Reply With Quote
I have a link pipe were the heater should be, ive also tried it with the heater circuit blanked off.
I also have a bleed from the radiator and from the inlet manifold. Theres no facility for bleed from thermostat body, but i could tap one in.
Ben
posted on 6/7/13 at 10:39 PM Reply With Quote
The overheating at idle keeps throwing my mind back to ignition timing, retarded timing causes a huge increase in heat energy rejected to the water jacket and exhaust.
Ben_Copeland
posted on 7/7/13 at 06:06 AM Reply With Quote
It's on a coil pack so I need to check the ecu to see what ignition timing it's running, but would that affect it whilst driving?
Ben
posted on 7/7/13 at 06:20 AM Reply With Quote
It may be possible to bleed by removing the temperature sensor while filling, works on the 8 valve Vauxhall engines . Putting an in line bleed in the by pass hose might help. If you still have the old thermostat try removing the valve section so you just have the outer ring in place , if that cures the overheating then the stat isn't opening, probably due to an airlock behind the stat
Ben_Copeland
posted on 7/7/13 at 06:25 AM Reply With Quote
There's holes drilled in the thermostat so hopefully it shouldn't have any air in there. But I'll try it again with temp sender out too
Ben
<<  2    3    4    5  >>
