<<  24    25    26    27    28    29    30  >>
Author: Subject: 2004 MK Indy Busa Project
yellowcab
posted on 4/2/14 at 08:58 PM Reply With Quote
B&Q
40inches
posted on 4/2/14 at 10:05 PM Reply With Quote
You finished the boot lid? A nice job it is too
Ben_Copeland
posted on 5/2/14 at 10:30 AM Reply With Quote
Top job as always.. about time you start driving it?
Ben
Locost Map on Google Maps
Enter Your Details Here
yellowcab
posted on 5/2/14 at 07:25 PM Reply With Quote
Only managed to get 10minutes or so last night, so just whacked on the edging, a metre is the perfect length which means it didn't even need to be cut lol
Just drilled a couple of holes, and screwed it down using the dome headed bolts that are holding the side pieces down, neatens it up no end, can no longer see the edge of the carpet, and gives my bootlid something to tuck under and hold it down nice and firm
So I've used the easily adjustable lap straps (pull away from buckle) from one pair, with the shoulder straps from the other pair - as my passengers will vary in size quiet considerably, from my 4 year old daughter up to 6ft 3inches of daveb666
Bought some threaded bar from B&Q for a costly £1.29, in order to make my seat mounts for my drivers seat
Got four of these aluminium things, which I'll drill through to create the 25mm spacer that I need
And my adjuster buckles for my drivers lap belt have arrived which means we're back on the road (after I've put it back together)
Oh, and just rolling the car forwards and backwards, the front drivers cycle wing stay catches lol lol lol
yellowcab
posted on 5/2/14 at 11:24 PM Reply With Quote
So I used the 25mm ally things, drilled them out and tapped them with an M8x1.25 thread
Cut some brass nuts in half, just to lock them into the seat nice and tight, aswell as thread-lock, as I didn't want the threaded bar to spin when trying to do the nyloc nuts up under the car
Ready for the seat
Harness locking buckles fitted to the existing lap belt of the 'single seater' harness
All sorted, just guessed the length and it was spot on...
Next up - whilst on track, my helmet rattles on my seat which pisses me off, so bought some black eva foam to make some head & bum protection (to prevent submarining and general movement)
But thought they looked shit, so I removed them, and made them from the black carpet that Dave got for me - cheers pal
Also some kidney shaped bum/leg pieces
yellowcab
posted on 5/2/14 at 11:27 PM Reply With Quote
Next up - I got cutting up some of the carbon goodies I had bought - I had my eye on a carbon passenger footrest on eBay which ended up selling for £132 eeeeek , so decided to make one from the bits I got
Got the saw out
Then the grinder, so it slots over the box section as the outside of the footwell gets narrower towards the front of the car
Job jobbed, proper happy with how easy it fitted in... all in all, a productive night for once
[Edited on 5/2/14 by yellowcab]
yellowcab
posted on 5/2/14 at 11:38 PM Reply With Quote
Ouch - £178
http://www.rallynuts.com/co-driver-hardware/obp-carbon-fibre-navigators-footrest.html
Ouch - £165
http://www.jjcraceandrally.com/race/pedal-extensions-footrests/sparco-co-driver-carbon-footrest
Ouch - £150
http://www.carbongoodies.co.uk/Universal-Carbon-Fibre-Footrest-for-use-with-Carbon-Footwells
CosKev3
posted on 6/2/14 at 04:06 PM Reply With Quote
Looks spot on and a big bonus when you see the price of those ready made ones!
yellowcab
posted on 7/2/14 at 04:51 PM Reply With Quote
Bit of a breakthrough finally, with having my trailer steels delivered.
An inpromptu visit from Mike up from Eastbourne, lead us to doing a late-nighter until 0100am this morning getting this little beauty built up.
As you'll probably remember myself and Colin (ReMan) buying a caravan Alko galvanised chassis and ripping the top off, and you'll probably have noticed the chassis being in the background on alot of the photos recently, so no anymore!
Maybe a lot of pointless photos here - but I'm documenting for my own benefit aswell as others also building a trailer
Front capping I/D matches the outer wall over the troughs O/D so it slots inside
The inside of each trough is only half the height, in order to be no where near the wishbones when driving the car, so a 50mm ally spacer made to bridge the gap, and tighten adequately
Again, for testing only - we got the widest of tyre combo I have, to checkout the trough width
Old jump lead ends are a handy mole grip for temporary fixing, this is the back of the trailer, with a wider box section, to allow room for the lights and number plate
So with the ramps just mole gripped to the chassis, and some make shift ramps (proper ones being dropped off tomorrow) we pushed the car up - to check the tow hitch weight
Still not bolted other than at the front to the box section, the car is resting on
Checking internal and external track width - perfect
Not trusting the handbrake too much, we temp rachted it down to the front chassis to prevent it rolling back
So we eyeballed it to begin with, but the hitch weight was too much for my liking, at 84.6kg
So we rolled the car back 6 inches, to imitate moving the troughs too, just to shift the weight, a perfect 50.9kg
However, I want a tyre rack, so we stacked the tyres as if the rack would be over the nose cone... but this left us overweight on the hitch again... 75.9kg
So to reduce hitch weight moreso, we opted to build the tyre rack over the bonnet, as opposed to the nosecone, which got our hitch weight down to 48.9kg, pretty cock on
But i want to make a lockable tool box to sit on the trailer to put all my straps in, tool bags, and general crap, so again we imitated this weight by using a couple of tool bags either side, and a slick tyre... aswell as the tyres sitting over the bonnet, hitch final weight of 63.3kg... perfect
[Edited on 7/2/14 by yellowcab]
yellowcab
posted on 7/2/14 at 05:01 PM Reply With Quote
So once we had our position, we used the original bolting & mounting holes in the Alko chassis to mark the underside of each trough, and thankfully my OCD will be OK - as the bolts & holes run dead centre up each trough - WIN/WIN
To allow trailer tyre clearance, we whipped the overhang off where the mudguards will be fitted
Cut two bits of wood the same length and temporarily jammed them in to make sure the parallels are bang on parallel and upright - they are
Bolted the front and back capping & number plate/ light board to the troughs, flipped it upside down, then drilled through where the marks are from the Alko chassis
Two slots in the Alco chassis enables this cross section to go in, to add mid-trailer rigidity, aswell as something to bolt the mudguards to to stop them flapping around
Box section back on, and bolted down
Cut out for the mudguards
The nuts & bolts of it all done and complete
Swap time
We've decided to reduce the length of the 'A' sections by a couple of foot, just need to finalise some bits & bobs, tart it up a little, paint the wheels, put the front mudguard stays on, edge trim, warning triangles etc..
Huge thanks again to Mike for coming up, and helping me out with the mammoth task, and then driving home to Eastbourne from Leicester at 0100am you're bonkers... but adamant he'd prefer to make the journey at that time rather than peak.
Thanks once again pal - appreciate it all.
daveb666
posted on 7/2/14 at 05:29 PM Reply With Quote
Some proper progress on the trailer, well impressed.
Puts my proper one to shame lol
daveb666
posted on 7/2/14 at 05:52 PM Reply With Quote
6ft4 I'll have you know
Ben_Copeland
posted on 7/2/14 at 10:26 PM Reply With Quote
Trailers looking awesome.
Ben
cosmick
posted on 8/2/14 at 08:18 AM Reply With Quote
Looks just like a bought one.
This is MK3 as I have built 2 others to the same design. This one has all the advantages of a few problems ironed out in MK1 and MK2. The joy of this one was in the preparation, everything was ready to just bolt it together on the night. It will look absolutely superb when it is completely finished.
If it can't be fixed with a hammer then its probably an electrical problem.
yellowcab
posted on 9/2/14 at 12:27 PM Reply With Quote
So spent a couple of hours this morning finishing off one of the mud guards
Where the mudguards do not fall 90degrees to the ground, you have to mimic the angle of the stay for it to sit nice and flush, its around 80-85degrees,
So bent one edge in a vice, to match this
Measured up and drilled through the stays and the troughs
Perfect mating angle
Ran the bottom of the mudguard along the bottom of the stay, so they're equal both front and back
Whipped off the guard, and offered up how i'll fix it to the side of the troughs
Insides of the mudguard all marked up
M8 bolted it to the troughs, then trusty M10 to the stays both front and back, these can now be stood on, and even driven over should I have to tow a wider car than mine
Next up, is to complete the infill
Seen alot of cars on trailers get absolutely filthy on the outside due to spray coming up in the wheel arch of the trailer, so wanted to fill this in
Template made - thanks to kids christmas presents
1.6mm ally cut out, and dome headed M6 bolted, which will also add a little more rigidity... I will be replacing the 4x M8 bolts for dome head too, so my should my tyre touch, they will just scrub by them
No splash getting through there now!
Thats it for today - family time.
gavink
posted on 9/2/14 at 10:12 PM Reply With Quote
More great work
yellowcab
posted on 10/2/14 at 04:34 PM Reply With Quote
Thanks Gavin, I know its slow progress but all is a step closer
Took the car out the garage on the trailer, and flipped it around so I wasn't working up against the wall
So the kids are growing up now, and now old enough to hurt themselves when they fall, so I've nicked their soft play mats, to save my ever aging knees from the concrete floor
No WIP shots - as it was the same as the other side, but the nearside mudguard fitting, exactly the same way was the offside
Complete with poo catcher
Front splitter/ under tray needed trimming under the sump guard now I have a dry sump, the pipework wasn't allowing me to fit it flush with the underside of the body, so I whipped off the removable access panel, and made the hole larger
Before and after
Just the sump guard to refit.
This one will actually be for sale, for anyone interested in buying it - as I'll need to make a new one due to the new nose cone sticking out at the bottom about 8inches further
[Edited on 10/2/14 by yellowcab]
Matt21
posted on 10/2/14 at 05:24 PM Reply With Quote
looks great!
Loving the trailer, I think I'll be making myelf one of the same design sometime this year. Just need to measure up to see if it will fit in the garage!
daniel mason
posted on 10/2/14 at 06:18 PM Reply With Quote
did you try reversing the car on but with tyre rack at hitch end?
yellowcab
posted on 10/2/14 at 06:20 PM Reply With Quote
I don't have a reverse Daniel, so forwards is the only way for me - then free wheel off, which is why I raise the hitch end so high
CosKev3
posted on 10/2/14 at 09:38 PM Reply With Quote
Nice work.
Bit disappointed no carbon fiber has been used on the trailer................
yellowcab
posted on 10/2/14 at 09:46 PM Reply With Quote
Yet
Trailers need aerodynamics too y'know lol
mccsp
posted on 10/2/14 at 10:08 PM Reply With Quote
Hi
Wish I had this much commitment and motivation.
Liking the nosecone, how did you find it?
Any idea what the black trim around the top of the rear panel is, pic below:
Keep up the hard work
[Edited on 10/2/14 by mccsp]
Why do it the easy way, when I can do things my way!
yellowcab
posted on 10/2/14 at 10:18 PM Reply With Quote
Hi pal,
Thanks for the reply, it's just 2inch wide black insulation tape from eBay, heated up with a heat gun as you apply it, to make it more conformance and stretches nicely
Hope this helps, good luck
CosKev3
posted on 11/2/14 at 08:15 AM Reply With Quote
Yet
Lol
As I was reading I really expected the inner wheel arch crap stopper was going to be carbon!
